Connection problem during setup: could not communicate with your Google home -error
ProfNFL
-Prompts:  Cancel OR Try Again ( try again does not work, just loops)
While adding a Google home speaker device back to Google home network due to a new WIFI router change, the Device connects to the Google home WIFI,  and sets up the Device  but when reaches connect WIFI password STEP it stops and errors.
Set up returns -> { Connection problem during setup: could not communicate with your Google home }  -error
Device shows four white dots that fade in and out.
NOTE:  I re-connected two additional previously connected devices with no issues.
This google home speaker device was removed from Google Home app and has been factory re-set multiple times {standard hold reset} , along with the instructions in Set up smart devices in the Google Home app.
Please advise on a possible solution or reason for error?    thank you .
8 REPLIES 8
Juni
Hi ProfNFL,
Thanks for posting and for being a step ahead of us. What Nest speaker are we working with? To isolate if this is network related, could you try setting up your Nest speaker using a mobile hotspot? See the instructions below:
(You would need 2 mobile devices: 1st is for the Google Home app and 2nd will act as a Wi-Fi network using mobile hotspot)
  1. Turn on the mobile hotspot of your 2nd mobile device.
  2. Reset your Nest speaker to its default settings.
  3. Make sure your 1st device is connected to the mobile hotspot of your 2nd mobile device.
  4. Re-run the setup on your Google Home app and choose your mobile hotspot as the network to set it up.
Keep me posted.
Juni
ProfNFL
Dear Juni,
Google Home Speaker : Model Home ( I believe 1st gen)
I am also having the same issue with Google Chromecast ( 1st Gen) .
Will not connect to new WIFI 5G
Please define 2 mobile devices?
1.  Mobile Phone w/Google Home App
2.  Laptop? or ?
thank you.
ProfNFL
ProfNFL
Google Chromecast ( 1st or 2nd gen.)
ProfNFL
Hi Juni, I was able to connect the home speaker device back to Google home app, tested the device and all seems operational. Thank you.
I will try Google Chromecast next.
Juni
That's good news. Let me know how it went with your Chromecast.
Juni
Juni
Hello there,
I just wanted to follow up to see if you still need our help. Please let us know, as we would be happy to answer any questions you may have.
Juni
Juni
Just checking in to make sure that you saw our responses. I'll be locking this thread if we don't hear back from you again in 24 hours. Should that happen, feel free to create a new one if you have more questions or have other concerns in the future.
Juni
