Correct (UK) power cable for Nest Audio
LiamHCollins
Hi
My power cable is no longer working and I can’t find a specific replacement on Amazon. Please can anyone share a specific power cable for use in the UK?
Thank you
10 REPLIES 10
Princesss
Hi LiamHCollins,
Thanks for reaching out to our Community.
We're sorry to hear about this. Is your device not turning on anymore? Also, do you still remember when and where did you purchase your Google Nest Audio so we can check your warranty options?
Princess
Hi
I bought it through UK google store. Order no. GS.0581-8644-6454. 18th Dec 2020.
Princesss
Hello there,
Thanks for the info you've shared. Upon checking, your device is already out of warranty and we can no longer replace it. However, as an option, you can check compatible cables with the same specs as your adapter. Here's some useful info: Google Nest and Home device specifications
Princess
Tried the specifications, I have now had two cables delivered that do not fit…i would have a list of compatible power cables on your website. Probably won’t purchase from Google again
Princesss
Thanks for responding. I really wish we could do something for you regarding this cable. We'd be happy to take a look into this for you. Please fill out our Contact Us Form with all the needed information then let me know once done.
Princess
Hi
i already did that on 27th November. I haven’t had a response even though the automated reply said 1-2 working days
Princesss
Hello Liam,
Apologies for that. I just want to check in-- have you been assisted via email?
Princess
No. I haven’t had a reply
Princesss
Sorry for the late response. Could you fill out the form one more time and let me know once you're done so I can check it right away?
Princess
LiamHCollins
This cable DOES NOT FIT 15W AC Adapter Fit for Google-Home-Hub, Nest-Hub (2nd Gen) Smart Voice Speaker Wall Charger Power Supply Cord https://amzn.eu/d/1OQA3E6
