12-19-2022 07:46 PM
Does anyone know what bitrate is applied when you have a Max Pair set up using an analogue audio in connection?
For example if I plug in an audio CD player via the AUX jack, the connected speaker will send that audio to the router which then sends it back to the paired speaker.
That line-in audio is an analogue connection though, so at what bitrate do the speakers send it to/receive it from the router is what I'm wondering?
12-25-2022 06:43 PM
Hey DanielRuben,
Good question! I'll raise this with the team and I'll get back to you for update.
Muddi
