Google Nest Hub Power Adapter
SavoirLife
I am in the UAE (same issue in UK) and just received a new Nest Hub 2nd Gen. In the box it came with a 2-pin US style power adapter. Does the Nest also come with a 3-pin UK style power adapter or is it ONLY supplied with 2-pin US style power adapter?
Secondly, if it ONLY comes with the 2-pin US style power adapter is it safe to use in the UAE & UK?
Cathal_S
Hi SavoirLife,
I'm a UK user and all my Google Nest products have been supplied with the UK three pin plug.
As the UAE is not a country where Google Nest officially sell their products you will have received the adapter from the country it has been imported from by a third party.
Device availability:
https://support.google.com/store/answer/2462844
I would think that if you use a adapter from the country the device came from to your country it should work. I would recommend contacting the place of purchase for advice using it in your region.
Cathal
LovelyM
Hello everyone,
Thanks @Cathal_S for sharing this information.
@SavoirLife, I'm checking in to see if you still need help. Please tell me if you have other questions or concerns. I want to make sure you're all good now.
Lovely
LovelyM
Hi SavoirLife,
We want to ensure you are good to go. Please reply to this thread if you still need assistance so we can give you a helping hand.
Lovely
LovelyM
Hey SavoirLife,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. We'd be glad to help you further so if you still need assistance, feel free to start a new thread.
Lovely
