Hi, @Kennne,
Thank you so much for posting in the community. I’m truly sorry that your speaker is not connecting to the Google Nest mini. Let’s work together and find a solution.
To assist you better, I'd like to know:
- Is your speaker already added to the Google Home app?
- Have you tried basic troubleshooting steps on your speaker?
- Are you receiving any error messages?
In case you haven’t added the device to the Google Home app, please follow these steps:
- Turn on your Bluetooth speaker and make sure it's in pairing mode. Press the pairing button on your Bluetooth speaker, if possible.
- Open the Google Home app.
- Make sure you're in the right home. The name of the home is at the top of the screen. To change homes, tap the arrow next to the home name.
- Tap and hold your device's tile.
- At the top right, tap Settings and then Audio.
- If this is your first time to use Bluetooth on this device, tap Paired Bluetooth devices and then Enable pairing mode, and then go back to Audio.
- Tap Default music speaker and then Pair Bluetooth speaker. Your Google Nest or Home device will then scan for Bluetooth devices.
- Tap the Bluetooth device once it appears on the screen and then Done.
Ana
