How to remove a device without gear icon
Agentblue
I recently moved, when I did my device went offline. Now at my new home I have factory reset it and it is working fine. However now in the home app I see the old device, it says it's offline so I don't see the gear icon to remove it. Any tips or ideas to get this thing removed?
2 Recommended AnswerS
David_K
Try these steps:
  • Open the Google Home app.
  • Tap Settings.
  • Tap Rooms and groups.
  • Tap the room the device was assigned to.
  • Tap the device.
  • Tap Remove device.
If those steps don't work, try these steps:
  1. Open the Google Home app.
  2. Tap your photo or initials at the top right.
  3. Tap Assistant settings.
  4. Tap Devices.
  5. Tap the device.
  6. Tap Unlink this device.
Agentblue
Hi there, the first comment seemed to work just fine. The device didn't show up on the list normally, however following those steps provided worked.
15 REPLIES 15
David_K
Try these steps:
  • Tap Settings.
  • Tap the device.
  4. Tap Devices.
  5. Tap the device.
Muddi
Hey Agentblue,
Happy to hear that your issue was resolved, and the steps provided by @David_K were able to help! It looks like we can consider this one complete, so I will lock the thread shortly unless I can help out with anything else.
Muddi
Muddi
Hey
As we got our resolution here. I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google speakers and we'd be glad to assist you further.
Muddi
78912
Ah the old ghost device - try David Kings steps, however I had this same issue a few years ago and the device you want to remove most likely will not have the "Remove Device"  "unlink Device"option. The only way I got rid of mine was to use my old phone with an old version of the GH app - that version allowed the deleting of old ghost devices. Once I removed the device I just updated to GH app to the current version. Good luck
Azarco
davidking and 78912, we appreciate the insights!
Agentblue, if the issue persists. Try creating a new home and move your Google Home or Google Nest speaker into it. Clearing the cache and data then reinstalling your Google Home app might help too.
Keep us updated!
Alex
Azarco
Hey Agentblue,
Checking back in to see if the troubleshooting steps shared help. Let us know by updating this thread, and the community will be happy to lend a hand.
Alex
Azarco
Hey Agentblue,
I haven't heard from you in a while so I'll be locking this thread in 24 hours. If you have any new issues, updates or just a discussion topic, feel free to start a new thread in the community.
Alex
Hi @78912! Do you remember what version of the Home App that allowed the deleting of an "dead" device. I recently cleared the Built-in cast data from one of my android TV's and now there's two TV's with the same name, One "dead" without the gear icon that I can't delete and one thats working. Does @Muddi or any of your colleagues know what version this is?
If i recall correctly I think it was  version 2.10.1.13, from April 19, 2019.
Thanks! 🙂
Aaand it worked! Thanks again @78912 🙂 Much easier way then to create a new home.
Azarco
78912, thanks for the information you've shared.
ChrisAhlund, great to hear that steps work for you! Do you have other questions or concerns?
Alex
No, not for this particular issue 🙂
Azarco
Hi ChrisAhlund,
Thanks for letting us know. I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google Nest devices and we'd be glad to assist you further.
Alex
Agentblue
