Maths problem again.....
SunnyRio
This is ridiculous.  It heard me correctly, but now can't do basic maths:
Me: "What's one and a half million divided by four hundred thousand".
Google Home: "The answer is one"
Me: "Repeat last question"
Google Home: "What's one and one half million divided by four hundred thousand".
Hi again,
When leaving feedback from the Google Home app you can also send activity logs to the team. This can help them finding issues, it would also help if you include a link to this forum post within feedback from the app.
Cathal
6 REPLIES 6
Cathal_S
Hi SunnyRio,
Please try the command again and immediately afterwards open the Google Home app and tap on your account icon and select 'Feedback'.
Leaving feedback is the best way to send reports back to the Google Nest team.
Cathal
I spoke "give feedback", and the google home took it by voice.  Does that achieve the same thing?
Hi again,
Cathal
Princesss
@SunnyRio, here's the complete step on sending a feedback:
Step 1. Turn on device reports
  1. Make sure your mobile device or tablet is connected to the same Wi-Fi or linked to the same account as your Chromecast, or speaker or display.
  2. Open the Google Home app Google Home app.
  3. Touch and hold your device's tile.
  4. At the top right corner of the screen, tap Settings Recognition & sharing.
  5. Turn on Send [device model] device usage and crash reports to Google. (Example: Send Google Home device usage and crash reports to Google.)
Step 2. Share your feedback
  1. Open the Google Home app Google Home app.
  2. At the top right, tap your account.
  3. Tap Feedback and then tap the type of device you'd like to submit feedback for.
  4. To display available emails, in the "From:" section, tap the arrow on the right. Select your email address.
  5. In the feedback summary, write a brief description of your issue.
  6. Be sure to check the box for Screenshot and System logs.
  7. To submit feedback, at the top right corner, tap Send .
By the way, thanks to @Cathal_S for helping out.
Princess
Princesss
Hello folks,
Princess
Dan_A
Dan
