Max volume too low
Wilson77
“Max volume” suddenly is about 10% of what it was before.
perfect 5g WiFi connections
rebooted all 9 minis a few times
sometimes a wave of normal volume comes through (for a second or 2)
ran in the exact same config for 3 years without any problems
also if playing on a single mini, so not only if streaming to speaker group
both manual tipping on device and central volume changes via app have same result
if connected to Bluetooth, volume works perfectly
Extremely annoying, any ideas?
Wilson77
I think I found the problem:
After a family bell was executed (which lowers the volume to make sure it’s heard), the volume stayed down and wasn’t corrected back to original.
Regretfully, the new “max volume” isn’t affected by just sliding the volume up again, it just stays where it is.
Any workaround known?
Dan_A
Hi Wilson77,
We're sorry for the trouble this has caused you. Let's check it out. Have you been able to get back the original volume using Family Bell? All 9 Nest speakers are Nest Minis or Google Home Minis? It would help a lot if you could do a sequential reboot first. Unplug the power cord of your router followed by your Nest speakers. Plug them back in after 3 minutes tops. Restarting your phone might also help.
Once done, make sure that you remove one Nest speaker from the speaker group and manually change the volume to high and see the difference.
Tell us how it goes.
Dan
Muddi
Hey Wilson77,
How's it going with your Google Home Max? Let us know if you still need help and the Community will be happy to lend a hand.
Muddi
Wilson77
Thanks Muddi, the solution is quite simple: remove all bells, add new ones, BUT ONLY ADD 1 speaker to ring! Don’t try the shortcut (Removing speakers without removing the bell), it doesn’t help!
Case closed.
The idiocy lies in the distribution of signals, for some stupid reason the “o so smart” developers didn’t think of “broadcasting” (through a router group) volume levels but do them IP-based directly to the destination (same reason you’re not able yo change volume levels throughout your house if you’ve got multiple speakers, really dumb)
Muddi
Hey Wilson77,
Thanks for updating the Community forum of your resolution — it's a big help! Also, we appreciate your feedback.
If you have any updates or just a discussion topic, feel free to start a new thread in the community.
Muddi
