02-06-2023 04:55 PM
I connected to the 5Ghz wifi network, I tested the right and left channel, the left one plays only in mono - two speakers at the same time.
The right one works fine.
I spent 5 hours trying to do everything I found on the forum.
Reset, reconnect, new group unfortunately still not working properly.
I connected at home to the same router in the same one room but to 2.4Ghz.
Stereo plays perfectly fine, but the distortion is very large - micro interruptions in streaming.
Despite the fast internet and short distance to the router, it may be due to the many devices on the 2.4Ghz band in the house.
The next small problem is that the "disconnect a pair of speakers" stereo option doesn't work - I had to do the factory settings every time.
Stereo still doesn't work properly.
Anyone have similar?
02-08-2023 06:24 AM
Done, it works correctly, for the 10th time of restart, I managed to connect correctly, put it in one room and the stereo plays correctly
02-08-2023 10:44 AM
Hi Szymon1,
I’m glad your issue is resolved now. I’ll keep this thread open for 1 more day. If you need further help, let me know.
Juni
02-08-2023 01:12 PM
Thank you everything is fine with only one pair of speakers I had a problem I have six nest speakers at home but only two did not want to play as they should.
speak soon in the future.
02-09-2023 08:03 AM
Thanks for getting back to us and we're glad that it's resolved now. We can consider this one complete. I will be locking the thread now. Feel free to start a new one and we'll be happy to help.
Juni
