Nest Hub Max - Camera Issue
pjmiller
Just got a Nest Hub Max and can’t get the camera to work. When I try to turn it on in Settings, the Home Monitoring Features toggle switch automatically turns off every time I turn it on.
I have a Nest Doorbell (battery) and Nest Cam (battery) set up and running.
I tried removing the hub from my home and doing a factory reset.
any ideas?
Thanks
Dburris
I have the same issue. Any update on this issue?
pjmiller
I had to remove the nest doorbell and nest battery cam from my Home then factory restore the nest hub max. Then add the nest hub max first. Once I made sure the camera worked, I added the doorbell and camera again. All good now.
GarrettDS
It looks like we have come to a solution so I'm going to be locking this thread. If you have any other concerns or questions, please feel free to create a new thread.
Have a great day.
Garrett DS
