Nest Hub Max is connected to another account or home
Optimus2025
Cannot reconnect to my display.  After factory reset, opened Home app and it shows in the app, but when try to use, is states "Nest Hub Max is connected to another account or home".
2 REPLIES 2
@Optimus2025
Usually you would get a message like that if you were trying to re-install a Google Nest device that had NOT been successfully factory reset.
Did your factory reset get the results documented here? (I.e., the Nest Hub reported it was resetting?)
https://support.google.com/googlenest/answer/7073477
If that's of no help, you could try contacting Support:
3. Select your device from the dropdown, click "Other", then click "Next step".
4. Under "Resources", just click "Next step". (Clicking one of the listed links will bring up a Help page.)
Optimus2025
There is no option to remove the device as stated in your first link.  Will work on Support
