06-10-2022 06:37 AM - edited 06-10-2022 06:40 AM
I've purchased my Nest Hub in Belgium. I live in the Flanders, which is the Dutch speaking part of Belgium. For some reason the language of the Nest Hub is set to French.
I can change the assistant's language to English, but the display's language (menu, date, ...) remains in French.
My Google profile's language is English UK, same as the assistant. I tried following the procedure mentioned in earlier threads, but my language is already set to English (UK) everywhere and even a factory reboot did not bring forth the expected change.
Please help me change the language of the device to English.
Karin
06-13-2022 12:54 PM
Wow! So, we seem to have found the SOLUTION for this issue! Thanks to this post: https://www.reddit.com/r/googlehome/comments/s5gd59/change_display_language_on_google_nest_hub_max/
What we did is we casted a Youtube clip to the Nest hub with the French menu from our phone (set to English (UK)) and lo and behold, the menu is now in English.
Here's hoping it will stay this way!
06-13-2022 11:35 AM
Hi Karin,
Thanks for reaching out.
I appreciate all the details you've shared. It's weird that you are still getting a different language on your display even if you have set it differently on your Google Assistant. Could you please check the device address that is set to your device and make sure it is on Belgium?
Here's how to change it:
Make sure that your mobile device is connected to the same Wi-Fi or linked to the same account as the speaker or display.
Keep me posted.
Princess
06-13-2022 12:28 PM
Thanks for your reply. I double checked, and the home address is correctly set to Belgium.
Just to make sure we are on the same page: I want the menus displayed in English.
At the moment the situation is:
I want all three to be consistent in English, as are all other (Google and Apple) devices on our home network
I hope we can get this fixed.
Kind regards,
Karin
06-13-2022 12:54 PM
06-14-2022 09:42 AM
Hi Karin,
Thanks for sharing some steps. So glad to know that it worked on your end.
I'll keep this case open for 3 more days so you can monitor your device's behavior and update this post if there are any changes.
Princess
06-18-2022 08:59 AM
Hi Karin,
Chiming in to check if you encounter any issues with your device? Let us know by updating this thread, and we're glad to help.
Muddi
06-20-2022 11:48 AM
Hi Karin,
I haven’t heard from you, so I’ll be locking the thread in 24 hours. Thanks for posting!
Princess
06-20-2022 11:51 AM
Hi there, that is fine. The menu and display language is still English, so all is OK.
thanks for following up
kind regards
Karin
06-21-2022 09:27 AM
Hi Karin,
Thanks for the update.
I'm glad that it's working good now on your end. I'll consider this post as complete and will lock the thread now. Thank you for posting.
Princess
