03-28-2023 02:18 PM
The nest hub 2 has a feature called: Low light activation.
I very much wish to disable this feature, as I sometimes have a dark room and want to be able to view video's and other content.
Please provide a way to disable: Low light activation or deactivate Low light activation once night mode is activated/planned.
Jesper
04-02-2023 10:21 AM
Hi Jesperb,
Thanks for posting.
Whenever the room is dark, Low-light mode will be enabled. It will be enabled regardless if Ambient EQ is on or off. When in Low-light mode, the display will either show the time or turn the screen off completely. You can adjust the settings for when to activate Low-light mode, and select what you’d like the screen to show during Low-light mode when you navigate to the Display settings on your Home app.
You can also try to disable the Ambient EQ on your Nest display:
Keep me posted.
Dan
04-05-2023 10:35 AM
Dan
04-06-2023 10:47 AM
Hello Jesperb,
Due to inactivity, I'll go ahead and lock this thread in 24 hours. We'd be glad to help you further so if you still need assistance, feel free to start a new thread.
Lovely
