Netgear Nighthawk connectivity issues with Nest Audio Speaker
Marcus1
I have a Nest Audio speaker that originally connected to an ASUS wifi router with zero issues.  I "upgraded" my wifi router to a Netgear Nighthawk CAX30S modem/router and now my Nest Audio device will disconnect after random periods of time to my router with the router message being that the WLAN access is rejected with incorrect security for my Nest Audio.  This issue occurs after hours, or sometimes days, but is becoming frustrating as this is the ONLY device that I have connectivity issues with.  ALL firmware is updated on router and Nest Audio, multiple encryption methods have been used with same results of disconnection, and I've even attempted setting up a static IP with the same results.  Any suggestions on what may be the issue.  Not having visibility into any logs or inter workings of the Nest Audio device is frustrating.  I'm suspecting it has to do with how the device manages it's encryption, but open to other ideas and more importantly, SOLUTIONS.
13 REPLIES 13
David_K
Try the following:
  • Disable Access Control.
  • Enable the option "Allow guests to see each other and access my local network" in the "Guest Network Setup."
Marcus1
Access control has been disabled and always was. What isn't clear for my model is all of the configuration that should be done around the guess network. Yes, I've selected the option you have suggested, but the guest network isn't enabled. Also, if the guest network should be enabled with that option selected, should i be connecting to that network as well? There's a lot more missing with that suggestion.
David_K
I recall those specific settings from previous posts with this router but don't own one personally so hard to advise more really.
Marcus1
Anyone in the community able to assist?
Hey Marcus1,
Sorry for the late reply. I wanted to follow up and see I could be of any help? Please let me know if you are still having any trouble from here, as I would be happy to take a closer look and assist you further.
Marcus1
Thanks for the response Jake. Still having issues.... I've isolated it to the way the nighthawk router handles it's meshed network and or relating to 5Ghz connection. The only way I can reliably stay connected is to have the speaker connecting ONLY to 2.4 GHz network. Any insight as to why that may be a limitation?
Hey Marcus1,
I would be more than happy to be of help. Some smart home devices only use the 2.4 GHz band and will not be available for setup if your phone is on the 5 GHz band. I did find an article with a little more details on that. Please let me know if that helps, or if you have any questions from here.
Hey Marcus1,
I am truly sorry for the trouble and frustration that you are having with the device. I understand that is not the most ideal situation, and I am more than happy to assist. Since you have exhausted all troubleshooting steps, I would like to escalate this to a higher team.
If you could please fill out this form, our Team would then be in contact with you for additional support. Please let me know if you have any questions from here as well.
Princesss
Hey Marcus1,
We just want to check if you have seen our response on the previous post? Let us know once you're done filling out the form so we can check it.
Princess
Princesss
Hey Marcus1,
We just want to check if you have seen our response on the previous post? Let us know once you're done with the form, otherwise we'll be locking the thread.
Princess
Princesss
Hey Marcus1,
Thanks for the update. Let's continue working via that channel so we can assist you further. Since there's already an ongoing case, I'll consider this post as complete and will lock the thread in 24 hours.
Princess
Marcus1
It doesn't help. The Google nest audio does not say anywhere what networks it can connect to, so just assuming that it qualifies as "some smart home devices" does not answer the question or solve the problem.
Marcus1
I had another ticket created off a related thread. Case ID [4-1502000032665]
