03-01-2025 09:30 AM
Hello, I have a 7” nest hub in my bedroom. At night I listen to ocean sounds at volume 5 for an hour while I fall asleep. In the morning, I need the volume on the alarm to be a lot louder. Can this be a possibility?
03-04-2025 01:49 PM
Hello nhnonna,
Thanks for reaching out to the Nest Community. We're happy to help you adjust the volume for your Nest Hub's sleep sounds and alarms.
Yes, you can definitely adjust the alarm volume on your Nest Hub! Here's how:
Adjusting Alarm and Timer Volume:
Open the Google Home app: On your Android phone or tablet, open the Google Home app.
Navigate to your Home: At the bottom, tap "Home."
Select your Nest Hub: Touch and hold your Nest Hub device icon.
Open Device Settings: Tap the "Device settings" gear icon in the top right corner.
Access Audio Settings: Tap "Audio," then "Alarms and timers."
Adjust the Volume: Use the slider to set your preferred alarm volume.
Important Note: This setting controls the general volume for alarms and timers on your Nest Hub. To achieve your desired effect, you can set this volume to a louder setting for your morning alarm and then use a routine to lower the media volume specifically for your sleep sounds at night. Remember, the media volume and the alarm/timer volume are separate settings.
Please let me know if you have any other questions.
Kevin
