Notification sound for Calendar Events?
Rockdocta
Hello - I managed to get my Outlook Calendar events to show on my Nest Hub by importing the calendar into my Google calendar. I can ask it when my next event is, and (if you don't blink), I can see a small toast message for a few seconds on the screen if I'm looking at it. Is there anyway to get it to play a notification sound when an event notification pops up? This works for Reminders,  I'd assume it would be pretty easy for Google/Nest to provide this functionality for events as well.
Additionally, it would be amazing if it could display the calendar on the idle/photo screen, the same way the Calendar Android Widget works on the phone.
Juni
Hi Rockdocta,
I totally understand that these are good features to use with your Nest Hub, but, these features are not yet available. I'd suggest you submit feedback about it, here's how
Let us know if you have other questions and concerns otherwise, we will be locking this thread after 24 hours.
Juni
