Setting up Nest Hub Max with Android TV results in no Netflix on Hub Max
Rdianco
Disclaimer: This thread was migrated from our previous version of the Google Nest Community. You can continue to receive updates on your thread issue here or simply ask, browse or more in the new Google Nest Community.
Original poster: Don Andrews 9626
I installed a new Nest Hub Max today. My existing system is composed of the following before I added the hub Max:
Google Nest Mesh WiFi System (Router with three points) One Extra Google WiFi Point
Google Audio Speaker.
An NVIDIA ShieldTV with Google Assistant enabled.
The issue I am having is that going through the setup and tutorial where the Hub Max is asking me to issue commands like "Start Netflix" or "Play {TV show} on Netflix" it ALWAYS starts Netflix on the Should TV. Even in the menu on the Hub under Media, I've tried pressing and holding on the button for 'Start Netflix' but it starts the ShieldTV.
This doesn't seem normal, and I'm trying to figure out how to get this working properly without disabling the link from the ShieldTV to my Google Account, as I like to use the assistant in the living room when I want to search something, or shut down the HUE lights in the living room.
Any ideas?
frances
Hi Don Andrews 9626,
Thank you for your post. I can definitely understand your concern, this seems like a very pesky issue. I would be more than happy to help find a solution. First, I have some quick questions.
  • First, since you have ShieldTV linked to your Google Account, it is your default service.
    • So if you command any apps or media, ShieldTV with react first.
  • Your best bet is to have a clearer command to override the default service.
    • What happens when you command "Start Netflix on Google Nest Hub Max" (saying the device name)? Does this issue still occur?
In conclusion, since you have ShieldTV linked, it will always act as the first service to your commands.
Please let me know if you have any other questions or concerns. Thanks!
frances
Hi All,
It's been a few days since we have heard from you. Just checking to see if this issue has been resolved. Feel free to ask any other questions or concerns you have. We're here to help!
frances
Hi All,
As I have not received any response, I'll go ahead and lock this thread. As always, feel free to start a new thread if you have any questions or concerns and we'll be happy to help.
