Hi @Zcf,
I understand how frustrating those pops and clicks in your new Nest's white noise can be, especially when it disrupts your baby's sleep. Here are some steps you can try to address the issue:
- Isolate the Issue:
- Try playing other audio content like music on your Nest device. If the pops and clicks only occur with white noise, it might be a specific issue with that functionality.
- Check for Updates:
- Make sure your Nest device has the latest software update. Updates often include bug fixes and improvements that might address audio glitches like pops and clicks. You can usually check for updates through the Google Home app.
- Restart Your Nest Device:
- A simple restart can sometimes clear temporary glitches that might be causing the audio issues. Follow the instructions in the Google Home app or follow this manual for restarting your specific Nest model.
- Experiment with White Noise Sources:
- While the built-in white noise feature might be convenient, explore other options to see if they work better. Here are some ideas:
- Google Home App: The Google Home app offers a variety of ambient sounds, including white noise, that might be less prone to clicks and pops.
- Streaming Services: Some music streaming services like Spotify or YouTube Music offer dedicated white noise playlists.
Try those steps and let us know if you were able to fix it.
All the best
Josh
