08-29-2022 10:25 AM
Getting super frustrated at this point. I had four Nest Minis set up on my network using a Google router plugged into a non-Google provider modem, then switched over to Google Fiber using the same equipment and now I can't get the Nest Minis to connect to my wifi network.
I have already unplugged everything for 15+ minutes, rebooted the network, factory reset all of the minis, forgot and reconnected to the network on my phone, uninstalled and reinstalled Google Home. I've checked that I'm not using mobile data, that wifi, Bluetooth, and location services are all on.
I'm getting a "Connection problem during set up, please check your Wi-Fi network settings" error, as well as a "There was a problem setting up your Nest Mini" error which takes me to a help page for "authentication isn't successful". The set up goes smoothly until I get to the point to connect to the wifi, where everything falls apart.
This issue only started when I switched over to Google Fiber, which is perplexing.
Would appreciate any help!
09-02-2022 05:30 PM
Hey my nest dose not even work, turns on and after 5 mins it get the "hang on while i connect to wifi" or "sorry something went wrong" this has been a thing for me after 3 YEARS and i just moved to amazon, in the mini market of smart speakers, google have let us all down and swept it under the rug, dissapointed in the device and google for not even trying to fix it
09-02-2022 05:32 PM
i use virginmedia and from the get go ive had issues from new unboxing setting up and no wifi switches, just the name, and that did not even cause the problem, my nest did all of this from 1st setup to 1 hour after setup i get the problems
09-04-2022 02:42 PM - edited 09-04-2022 02:43 PM
Thanks for visiting the Community and I'm sorry to hear you're having problems connecting your Google Nest Mini to your network.
Are you using an Android or iOS? If you're using an iOS, give these steps a try: Go to iOS Settings> Wi-Fi. Connect to the Wi-Fi network that matches the device they're setting up. Look for something like GoogleHomeXXXX.k, GoogleHomeXXXX.o, or GoogleHomeXXXX.p. Navigate back to the Google Home app. The device should now be detected. Start setting up your device.
If the issue persists, try the steps below:
Let us know how it goes.
Alex
09-07-2022 03:00 PM
Checking back in to see if the troubleshooting steps shared help. Let us know by updating this thread, and the community will be happy to lend a hand.
Alex
09-08-2022 03:52 PM
Due to inactivity, I'll go ahead and lock this thread in 24 hours. Feel free to start a new thread if you need assistance with your Google speakers and we'd be glad to assist you further.
Princess
