01-11-2022 01:53 PM - edited 01-11-2022 02:00 PM
I have a CCWGTV connected to a VEMONT USB 5 in 1 HUB (https://amz.run/5Df6), with a UGREEN 65 W CHARGER (65W PD Fast Wall Charger – UGREEN). The USB ports on the HUB work properly and without issue with Dual Shock game controller, flash memory, and so on. But the Ethernet works inconsistently. It will work for a few hours after everything is plugged in but if the CCWGTV goes to sleep most times it won't work when it wakes up. Other times I simply can't get it to work no matter how many times I disconnect and re-connect everything. I have tried the HUB with my mobile phone and it works fine, even the Ethernet. But with the CCWGTV it's hit and miss. It worked fine for the first couple of weeks and then it didn't. I have troubleshot all cables. I am not sure, but I suspect the issue has to do with the CCWGTV going to sleep and being unable to wake up the Ethernet connection. Any help appreciated. Thanks.
04-26-2022 01:56 PM
Hey bb2021,
We hope you were able to get the help you need. If you still need assistance with your Chromecast with Google TV, feel free to submit another post and provide as many details as possible so that others can lend a hand.
Alex
