No connection to ZyXEL AX7501-B0 with Chromecast Ultra
alexs77
Hello
I'm trying to connect my two Chromecast Ultra devices to my ZyXEL AX7501-B0 WiFi router. It just doesn't connect… 😣
I did factory resets of the Chromecasts and also the ZyXEL WiFi router. After that, I started the Google Home app on my Android phones (tried multiple; lets say it's a OnePlus 7). It finds the devices and suggests to do a setup. I see these 4 digits/chars on the screen and confirm that I also see them on the app and then I try to connect it to the WiFi.
It fails. After a period of time, it shows that the connection is not possible.
The Chromecasts are also connected with LAN cable. Does not help.
The WiFi itself works just fine; other devices can connect and Internet connection is possible.
It never used to work with this WiFi; before that, I was using an AVM Fritz!Box.
Any ideas?
AlexS77
alexs77
I had a DHCP server on a Raspi in my network running - had totally forgotten about that 🙈
After turning it off, everything works like it should.
alexs77
Hilary
Community Manager (Admin)
It looks like you were able to find a solution. Please let us know if you have any other questions or concerns as I will be locking this in 24 hours.
Have a great day!
Hilary
Hilary
Hey Folks.
We haven't heard any updates from you. I'll go ahead and lock this thread. If you're still experiencing problems, feel free to start a new thread and we'll be happy to help.
Hilary
