Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-09-2025 01:50 PM
Same here, wanted to watch movie, "Chromecast can't be verified". Tried everything Google Help suggested, nothing works..
03-09-2025 01:52 PM
My Google Chromecast worked perfectly fine last night, then when I turned it on today ambient mode under Google home was no longer working. I tried to redo my settings, but it said that it was unavailable. After receiving an error message that my Google Chromecast couldn't be authenticated even though the Chromecast numbers were matching up on my TV and in the Google home app , I clicked the link it gives you for help and tried all these steps below . I tried rebooting my Google Chromecast after unplugging everything for a minute, that still didn't work. I tried rebooting mobile phone, and cutting on and off the bluetooth, but that didn't work. I unplugged my internet and router for a minute and replug that in, that didn't work I uninstalled the Google home and reinstalled the app, and that didn't work. Nothing has worked that worked in the past, and now I see people from around the world have been posting issues with their Google Chromecast over the last several hours. Google needs to get their crap together and get the problems fixed now!
03-09-2025 06:19 PM
Da same happens to me, since like 5 hours ago.. wtf?
03-09-2025 01:53 PM
Same issue here. Reset Chromecast to factory settings then tried to add from Google home app. It shows a code on my TV screen but then says " cannot authenticate your chromecast". I have a Chromecast V2. Is there a page we can go to to get updates on progress?
03-10-2025 06:47 AM
TENHO A 3 GERAÇÃO...
A 1 ESTA SEM SUPORTE...
POREM A ATUALIZAÇÃO FOI PARA TODAS AS VERSÕES E EM TODOS OS PAÍSES...
AS PESSOAS ESTAO NO X RECLAMANDO 24 ORAS FORA DO SERVIDOR DO GOOGLE ...
MUITOS AGUARDANDO E VÁRIOS COMPRANDO STICK AMAZON ...
É O QUE SE TEM DE INFORMAÇÕES...
ABRAÇO DO BRASIL
03-09-2025 02:03 PM
Seems to be the same problem here.
both my chrome cast suddenly went offline in the google home app. Can’t connect with any streaming app.
tried factory reset on 1 device but can’t finish the setup now…getting a feeling they are bricked now. What the heck happened?
03-09-2025 02:30 PM
Estoy igualll me paso exactamente
03-09-2025 02:16 PM
Worked this morning, then my chrome cast stopped connecting with my phone. Gives the you TV my be setup but there is no communication with your iPhone. I have done everything under the sun to troubleshoot. What is the issue?
03-09-2025 02:19 PM
Having the same issue here - seems like there is a major down for all using Chrome Casts..
03-09-2025 02:18 PM
I can see in all tech forums that this is an issue of today all over the would that Chromecast 2 at least (not 1 however), stops receiving streams, mine too. I could see that I have the latest update of the firmware of 24/2-25: 275994 (https://support.google.com/chromecast/answer/7124014?hl=en#zippy=%2Ccurrent-production-firmware-vers...), so I used the guide to regain streaming. All easy first points on the list failed, so I got to the factory reset and performed. Here the Google Home app (also newest) will not authenticate, so now I'm locked out. Home app also have the 24/2-25 release date, so what could have happened making so many devices fail simultaniously?
Seems that the development team will have a busy day or two ironing this one out. First I guess you need to update the home app to authenticate devices that has been factory reset, so devices can get online again and then fix firmware to allow for streaming again.
03-09-2025 02:34 PM
good investigation. the only consolation is that if its this wide spread, there will be some action taken by the powers that be. Meanwhile, ALL my streaming services aren't very useful, Thanks for the input
03-09-2025 02:25 PM
Eu sou do Brasil e o problema não e no Chrome cast. A atualização do app Home não está reconhecendo os aparelhos da geração 1, 2 e 3. Tem que ser feito uma nova atualização. Podemos fazer a reclamação na play store e dar menos estrelas pra ver se resolve o problema mais rápido
03-09-2025 02:31 PM
Chromecast 3 está funcionando. 2 não.
03-09-2025 02:30 PM
Same problem. I reset the chromecast. Impossible to reconnet. Error message " we couldn't authenticate your chromecast "
03-09-2025 03:20 PM
Nekem is ez a problémám. Mi a megoldás?
03-09-2025 02:31 PM
Está reproduciendo y salió ese mensaje no se pu de autenticar Chromecast no sensibles por alguna restricción o versión de fimeware. Hemos seguido varios pasos de ayudas y ninguno funciona. Varias personas reportando en diferentes fotos está anomalí
03-09-2025 02:34 PM
Según foros es a nivel mundial... Canada, Argentina, España, etc. No funcionan los Chromecast gen 1 y gen 2
03-09-2025 02:30 PM
Adding our frustrations. Exactly the issues - Untrusted device, then can't authenticate after factory reset. UK.
03-09-2025 03:01 PM
So it must a system issue I thought it was just my device
03-09-2025 02:35 PM
Que esta pasando alguien sabe? Esta mañana ya no pude mas transmitir contenido desde el celular a mi chromecast.
Al volver a la configuracion de fabrica e intentar configurar nuevamente salta un error y dice "no se pudo autenticar tu chromecast"....
03-09-2025 02:38 PM
Según Google están trabajando en el tema.... No especifican que ha pasado no cuándo se solucionara
03-09-2025 02:36 PM
Maybe Google just wants us to buy the newest chromecast 😭
03-09-2025 02:38 PM
Es probable 😒
03-09-2025 02:44 PM
All my older Google chromecast audio devices are now not connecting, but my other brand ones are working,
03-09-2025 11:09 PM
Which other brand ones are you using?
03-09-2025 02:48 PM
So does this mean I have to buy a new Chromecast device?
03-09-2025 02:56 PM
That’s it. Welcome to Google logical for ecology thinks
03-09-2025 03:05 PM
All three of my gen2 have completely stopped working early evening on 09.03.25. Please fix ASAP. Thanks.
03-09-2025 03:19 PM
Same here, so annoying 😭
03-09-2025 03:10 PM
Estaba usando chromecast, luego no pude usarlo. Después de resetearlo no se puede configurar y añadir a Google Home. Me dice que no se ha podido autentificar mi Chromecast ¿Alguien sabe que pasó o que puedo hacer?
03-09-2025 03:17 PM
El mío está haciendo lo mismo, no se como hacer.
03-09-2025 03:17 PM
I have 2 chromecasts both of the same network and there both working seemlessly without any issues, i returned from work today one of them doesn't seem to connect, even though its connected to the internet and show the screensaver with the clock on the bottom right
at first i thought it was my internet that was the issue but the other one was working fine
so i did the following
1- I restarted my router
2- hard reset this chromecast
3- Tried connecting from my iphone
4- Tried Connecting from another phone
5- Changed the TV
6- Changed the wifi network to another
7- Deleted my google home from both phone and installed them again
8- Removed any access point
9- changed the HDMI ports
10- Changed the power port
11- hard reset 3 times
12- checked that local network access is enbaled on both phones
13- disabled and enabled just in case
14- restarted both phones just in case
all with the same message
"something went wrong
family room tv maybe setup, but we could not communicate with it from your iphone
make sure that you have enabled local network access in your iphone's privacy setting, then try again"
hope anyone can help with this, it's so frustrating for the device to suddenly stop working
03-09-2025 03:20 PM
ME ESTA PASANDO LO MISMO. SALUDOS QUEREMOS SOLUCIÓN.
03-09-2025 03:18 PM
Não foi possivel autenticar o chromecast
03-10-2025 08:54 AM
Same message here
03-09-2025 03:20 PM
En México hay fallas al intentar utilizar Chromecast lo reinicie y no me permite nuevamente enlazarme apareciendo un mensaje de que no se puede enlazar
03-09-2025 03:23 PM
Si hay fallas tiene todo el día de hoy que no se puede conectar chromecast. Soluciones Google
03-09-2025 03:26 PM
I just understood what happened to us now... Chromecast V2 was loaded for sale on 2015.
10 years later, you can now throw it to the garbage
03-09-2025 03:52 PM
Hope this is not true. There was no announcement, this device is still very effective and performant. I do not think that we have security risks or vulnerabilities. They should extend the gen2 lifetime support
03-09-2025 03:33 PM
Не працює,не бачить роутер- нічого не допомагає.Виправіть
