GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,162 REPLIES 16,162
I reserved my Chromecast gen 2.  How will you inform your client about the fix?  I do not want to come here each day.  Do you have an expected date for resolution
Minha TV está ligando sozinha, e ainda assim nao consigo configurar meu chromecast. Pelo amor da deusa, resolvam isso o quanto antes!! Ou pelo menos nos deem um prazo mais acertado!
Espero que a Google respeite as pessoas que confiaram no produto oferecido e resolvam o problema o mais rápido possível
Anonymous
Not applicable
I can't even cast at all
Meus dois dispositivos estão com problema. O Google já não é a mesma,
Restablecí la configuración de fábrica. Me pueden avisar cuando se arregle?
I have done factory reset and it cannot even connect to home wifi now. Hoping to get a fix and next steps from you as soon as possible.
Roll out? Why can it just be implemented across the board?!
would really love to play music in my house again!
How much longer do we have to wait? Several days have passed, and there's still no solution. Users around the world are affected and awaiting a response.
My 2nd gen Chromecast was not factory reset, and it is still not working. Need a fix ASAP
Advice to not factory reset would have been useful earlier on. When I first noticed the issue, the only advice I could find online was to do a factory reset. So now I have two Chromecast devices that don't work.
Por favor façam essa correção o mais rapido possivel
Bnas noches ya está en funcionamiento Chromecast 2da generación gracias ...Mendoza Argentina .
KCCR
I have just checked and it is still not working. Same error code 2280.
Any updates on solutions for the ones that have been factory reset?
Thanks
Hi there, I have a 2nd gen chromecast and it stopped working and won’t connect to our home wifi. During this time, I performed a factory reset- therefore, i can’t seem to re-set up my device. Please contact me or update me when there is a solution. Thanks
How long it still take to get resolved?
my google chromecast 2nd generation device suddenly can't authenticate please fix it ASAP
Boa noite!! Eu realizei a redefinição de fábrica, fico no aguardo de novas orientações sobre como resolver o problema da reconfiguração.
Danke dann hoffen wir mal das beste,...👍🏻🍀
I’ve done the reset including modem and swapping tv three times. Now stuck on the can’t talk to the phone but is on the network
It is styem errors,not need to rest just wait
Hi there, I have a 2nd gen chromecast and it stopped working and won’t connect to our home wifi. During this time, I performed a factory reset- therefore, i can’t seem to re-set up my device iPhone . Please contact me or update me when there is a solution. Thanks
I have followed the indicated procedure, including the factory reset. I would like to understand how communication will be handled moving forward, as it has been mostly reactive so far. Is there a plan to address this situation proactively?
Tellme if I need to by other device ?  Naturally not from google.
Anonymous
Not applicable
Who wouldn't factory reset first. Credit for finally sending an email to users but a few days too late. I hope that hasn't bricked the device.
Just cheking to see the updates
Please, fix ASAP and find a solution for people who rested the chromecast.
I performed a factory reset on my Chromecast before reading here that there is an issue.  How do I reconnect?
Si ma quando??? E piu di un mese che non riesco più a usare il Chromecast
I dont think I could ever trust in Google the same way. I wake up at 6 am, get gome at 10 pm, I just want to enjoy myself. Already 4 days? Cmon!
Anonymous
Not applicable
Aquí seguimos esperando con paciencia, ojalá no tarden mucho, yo si hice el reseteo de fábrica 😞
Shoot... factory reset was one of the first things I did. The next was to come here and see not to do a factory reset.
"Your device must be connected to receive the update."
So where will will we find the information that it's fixed? Here? I haven't received even one email from Google about the outage, let alone any updates.
Alguém sabe quando volta?
Cuando recibiré la actualización?
I have rebooted both of my Chromecast 2nd gen devices. Only 1 accepted the update and is now working. The other tried to download the update and failed, and subsequent reboots it does not update the firmware, just boots up as before and is “offline” in the Google Home app
Ok, We are waiting. Pls speed up.
