GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,142 REPLIES 16,142
Rw6
What is your expected time range to have this fixed?
Kels2
I have managed to get Chromecast reconnected, unable to stream anything but at least it's back online.
I have Samsung device went into settings
General settings and manually reset the date went back on to home and connected Chromecast straight away.
Thanks for the help just waiting for fix now.x
Fabtax
Hello all!
I just wanted to say that's really a pitty not able to manage SSL certificate properly on millions of devices that we, customers, bought.
I also wanted to point out the poor communication from Google linked to this issue.
I spent almost 2 hours to debug it and to understand that the issue was not coming from my side.
I'm really upset.
I wanted you to know.
Regards
sherik
How did you determine it's a SSL Certificate issue?
MC6367
After spending hours trying to figure things out with my chromecast, I ended up doing a factory reset and now it will not connect to my WIFI. Keeps telling me I need to check my local network settings on my phone.
Kels2
Change the date on your phone in settings and then try again on the home app, I have just done it and it's reconnected.
defekt
... puh, ich hoffe sehr bald auf eine lösung...
und natürlich habe auch ich mein gerät bereits zurückgesetzt :(!!!
wo bekomme ich die nötigen informationen zur reaktivierung des gerätes bereitgestellt?
Derik64
Resetting was the first I tried 😞
I hope you will fix this soon, my whole music system runs with four Chromecast Audios.
MP60
I did factory resent since it was imposible to know what was going on. it still not connecting to the wi-fi, and yes I did all the troubleshooting steps one by one more than once. Nothing worked. and there's no wi-fi issue with any of my other devices including a roku I have in another TV unit.
Blushojun
I did the factory reset on my device. Please reach out to me once the problem has been fixed. Thank you
Michiel1
Helaas te laat met zien van het
bobby2344
too late answer, i've reset device like 4 times. Im looking forward for instructions what next
rokit1
Will Google replace the device if it cannot be fixed after a Google-recommended factory reset?
Michiel1
Helaas te laat dit bericht gezien ik heb 2 audio cast die nu niet meer bruikbaar zijn. Kunnen jullie het product niet opnieuw produceren. Of hebben jullie daar te weinig winst op?
Brianwil
Bit late as most people will factory reset to try and fix there Chromecast audio etc. I have spent hours trying to connect then factory reset before reading this post. How will users get a fix ? Regards
sherik
Honestly, Google?  All of this over a SSL certificate? WTH?
Pete90
Speriamo ragazzi rimettetelo in corsa!🙏🏿🙏🏿🙏🏿
Maybeth
ósea en serio? necesito que solucionen esto
JohanP
For those who did a factory reset: as proposed in one of the previous messages:  because it seems tot be a certificate issue: if you change the date of your cell phone tot 6 of March you Will be able to re-install the chromecast device. It will not help you to be able to cast again but you will have  the same status as those who did not perform a factory reset. And finally we will have to wait Google for their certificate renewal.
jonnyh179
Great, so in the meantime you will be  sending me a new Chromecast that works, because watching TV on my Pixel 9 Pro XL sucks. That's right, a loyal Google customer for years just waiting for Google to get their act together... Apple anyone?
MV94
My Chromecast suddenly stopped working,I tried almost all troubleshooting but still not working,It shows the error "we can't authenticate your Chromecast" Factor reset didn't help.Please help
Aurelie85
Bonjour, merci de votre réponse malheureusement j ai déjà réinitialisé mon appareil. Du coup en attente de vos instructions quand le problème sera réglé 😊
Ntgick
Well... I followed the instructions on Google home and reset it... Thanks!!! ...how will you inform me of the instructions to correct the device?
Kels2
Change the date on you device that has the home app on, go into settings to do this. Then try to reconnect your Chromecast through home app. I have just done this and it reconnected. Can't cast untill fix is done but at least it's reconnected.
Cynlee
I give up - going to Wal-Mart to ck out their Roku device or something similar
Nazza
Hi, I factory reset long before your post because that way what the general steps suggested, can you please help now.
sherik
Really, Google?  SSL Certificate issue? Daylight Savings Time snafu?  WTH?!!!
Dreamerdee
It’s been over 24hrs since chromecast went down. It’s a disgrace you haven’t been able to fix it, and worse, that you did not communicated with your many unhappy customers yesterday when there was clearly news on social media of a widespread issue. Shame on you.
caeds3401
Acho que infelizmente rackearam o chromecast e colocaram vírus no seu sistema 😥
Sashman1903
I thought it had broken and is my only streaming device. Have now paid for an amazon firestick. I want a reimbursement for my £40 as it is your fault.
Gabriele80
Speriamo risolvano...
Sarahlmountford
When will you tell us its 2 days now
FabFasc
Io ho provato a ripristinarlo, pensavo era un blocco dato da un aggiornamento l. Come devo procedere?
PeppyHyperspace
Is there any way I can get a notification when the problem is fixed?
enov
Thank you for information.
Any estimation?
Jeroenheinen
I hope its working soon again, how can i check the latest news? We allready reset the device, it was one of the options that you read like: on every page…
A_Nichols
Have the same problem, my cromecast continued to be connected to my TV as was displaying the images from the google gallery on standby but stopped responding to controlling devices such as android tablets and also my IPhone. I tried  fixing it by rebutting my modem (router) then rebutting my Cromecast by disconnecting it from the power for two minutes, reinstalled the google home app and at the end resetting the Cromecast by pressing the button on the side of the Cromecast, then when I get to adding device on the setting process in google home app it finding the Cromecast but next falling to connect it as saying that it "couldn't authenticate my Cromecast". Please help!
A. Nichols, Australia
I have done all your steps too, with the same result. Arghhh, took me hours!
Rickyc560515
Listo, cambié la fecha y pude reconfigurar mis 2 chromecast sin problemas. Gracias a todos por sus aportes.
Ma come è possibile modificare la data dopo aver resettato tutto?
