GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Quelin
Olá bom dia, restaurei meu aparelho e não estou conseguindo acessar novamente para configurar, segue até etapa de localizar mas quando abre o código não segue o processo. Como faço ?? Deve trocar de aparelho este não vai mais voltar a funcionar ???
Leozinho92
Só alterar a data do celular para 8 de março de 2025 e tentar novamente que dessa vez dá certo , por em só conseguir configurar ainda não estou conseguindo abrir qualquer app YouTube , net flix e etc , falta só a atualização deles . Cuidem
RadicalBox
Hope your fix will support devices that has been reset as that has been the standard way to fix things before and I guess no one really reads this message until they see that a reset does not fix it. Really poorly managed.
RedFrk
Is this impacting JBL Link speakers as well?  My 3 chromecast audios are all offline and still haven't received the fix, but also my JBL Link 10 speaker that supports chromecast casting.
Jenzeiner
I’m disabled and in my haste, I can’t recall if I did a factory reset. How can I tell?
You normally do a factory reset by long-pressing the button on the Chromecast itself. Do you remember doing that? 🙂
Anonymous
Not applicable
I had to unplug and reconnect my device before the update began installing. All's well after that
Interesting. Are u in the U.S.? I plugged and unplugged all last night still no update 😀
Simon1er
Please let us know when this first deployment phase is completed from your point of view.  I didn't factory reset my chromecast, but it doesn't seem to be connected to the network anymore.  I have a real doubt that this fix will work for me.
If you didn't factory reset your chromecast, it should still be connected to your Wi-Fi network, even if the Google Home app (misleadingly) says that it's "Offline". It's only "offline" from the app's point of view because it can't connect to it due to the authentication bug.
If you really want to make sure, you should be able to go into your router's setup page and see if the Chromecast is listed among the connected devices.
Tym59
Pour moi ça refonctionne, j'ai mis une date sur mon téléphone antérieur comme le 05 mars, j'ai réinstalle via home en remettant le réseau Wi-Fi 2.4g disponible, il a suffit ensuite de couper l'alimentation du Googlecast2, relancer,  et j'ai vu une annonce de mise à   jour apparaître... il suffit de laisser faire en patientant un peu, et ça refonctionne normalement, bravo google d'avoir sauvé ce vénérable petit équipement 😉
earlgrey
I think that Google & Co are becoming way too entitled. DO NOT TOUCH the hardware which I own. If I want to update the firmware then I will do so. Get the F*** out of my devices.
Okay, so you don't want the firmware fix that they started rolling out yesterday? 🙂
Johnny Smarty, do you want to work on your reading comprehension, or do I need to spell out the semantics of my previous message? Or maybe you are just too young to understand what I was saying, being addicted to algo feeds and auto updates, considering this as "the new normal"...
David1701
Is there any further updates?The Chromecast are the main device for entertainment in my home
Read the pinned status update at the top of this page. Google started rolling out a firmware update fix yesterday.
Chantal-25
Merci beaucoup j’ai suivi vos recommandations et tout fonctionne musique et vidéos 😌👍
Casarrubia66
Por desgracia, fue lo primero que hice el domingo. Resetear y restaurar a la configuración de fabrica
Carlosgote
Mucho estan tardando ya para corregir una fallo que han generado ellos mismos creando las licencias limitadas a 10 años cuando crearon el Chromecast. Cuanta gente hay trabajando en el error?. 1 persona?. Muy mal!.
Read the status update pinned at the top of this page. Google started rolling out a firmware update fix yesterday.
Anonymous
Not applicable
What is the ETA for fix if a factory reset was already performed on the device?
Mismarlof
I have reset my Chromecast. What do I do then? For how long time do you think this is going to be broken?
EugeneSko
Finally FIXED
Just got the update and now everything works great!
Turn on the device and keep it connected to the network. You will see the update message soon.
For those who did a factory reset, use the trick to set the date to March 8th or earlier on your mobile device (you can change it back later) and reconnect (add as a new device) the Chromecast to Wi-Fi to get the update.
It's Friday! 😎
Age7
Acabo de desenchufarlo y volver a conectarlo y ha comenzado a actualizarse. Se ha reiniciado y.... Parece que ya funciona!!!!!
Koalia
Hi ! Before reading this message I've already performed the reset....
What can I do to make it work ?
Thanks for your answer ☺️
Para todas las personas que restablecieron los valores de fábrica y se están asustando y preguntan "¿qué hago ahora?":
1)  Establezca temporalmente  la fecha en su teléfono inteligente (o tableta) al 8 de marzo o antes.
2) Usa la app Google Home para volver a configurar tu Chromecast. Seguirás sin poder transmitir y el dispositivo aparecerá en gris en la app Google Home, pero no hay problema. También puedes volver a configurar la fecha y hora de tu teléfono a Automático.
3) Siéntese y espere a que se instale la actualización de firmware de Google.
Supuestamente será un lanzamiento gradual, por lo que la actualización de firmware podría tardar varios días en llegar a tu dispositivo. Paciencia.
Go back to the top of this page. Look at the second paragraph.
Faiz1
What can I do if I did a factory reset? And the chromecast isn’t available in the Google Home App?
For all the factory reset people who are freaking out and asking "what do I do now?":
1) Temporarily set the date on your smartphone (or tablet) to March 8 or earlier.
2) Use the Google Home app to re-setup your Chromecast. You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Also, you can change your phone's date/time setting back to Auto now.
3) Sit back and wait for the firmware update from Google to be installed.
Supposedly it's going to be a phased rollout, so it could take as long as several days for the firmware update to hit your device. Patience.
Kumar12345
How long do I have to wait please tell me something about it
Bagsværd2025
Ok so it has been several days now - I am fully reliant on my Chromecast devices as I stream all content. When the f*** are you going to tell all of us what to do to get our casting back?
BlueBox
I already did factory reset, it’s not my problem that the device has factory reset button !!!!
If you have already factory reset your devices and are now unable to complete setup, setting up the Chromecast with the phone's date manually set to before March 9, 2025. This worked for me. Then leave the device alone while google pushes out the new certificate.
Jeff_Wags
After adjusting my date on my phone, re-adding the chromecast audio, changing my date back on my phone I am able to cast to my google audio without issue. Not sure if my device just picked up the updated certificate as it connected back on the network or if I just have good luck in this moment. Time will tell if it holds over the next few days of casting. Good luck!
