GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,151 REPLIES 16,151
Jorge55
Obrigado pela atenção, fico no aguardo meu email se necessário é #
Jorge55
Se necessário contato meu email #
Nouser69
Try just setting up a local dhcp server with the NTP option in it set to your own machine and make the NTP server only sync time we rh your own machine and är the time back a year or so and see if that works
Leonardo1955
Some users suggested to change the date of your smartphone  manually to 7 March and that did the trick for me. After that I could connect my Chromecast in the home app and the software update that fixed the issue was installed.
Silprada
mesmo após informarem que foi solucionado problema nos aparelhos, aqui até reconhece, mas vem mensagem que não foi possível acessar. não restaura
Antonella08
please i need a very urgent solution !
jacr0006
I reset it to factory as suggested by your owner website. How can I fix this?
RICAMBI
HELLO I DID THE UPDATE, THE CROME UPDATED AND NOW I CAN PROJECT FROM THE PC WITHOUT GIVING ME THE ERROR...BUT SERIOUSLY ON THE TV MONITOR IT SAYS "NOT SUPPORTED" AND THE SCREEN REMAINS BLACK. PLEASE LET ME KNOW. THANKS
Marina1eart
Non è ancora stato risolto il problema?
Bolangera
Estáis tardando demasiado en encontrar la solución. Llevamos más de una semana esperando y, además, avisastéis tarde de que no restableciéramos los valores de fábrica. Vamos a empezar a buscar otras alternativas de otras marcas.
Teejayone
Why did this happen?
mdrimonrana
Riyadh
Amit_th
I have been told that you are working on a fix for “Chromecast unable to connect to local network”. When you people are going to fix it or shall I buy Amazon fire TV?
I was able to fix the error thanks to AI advice. The problem appeared on 9 March 2025. I reset Chromecast to factory settings, then manually changed the date on my phone to 8 March 2025, chromecast updated, then returned the date to the automatic date and time settings. Now everything works.
MonicaBolton
Any update on a fix for this?
AndriiBakush
I was able to fix the error thanks to AI advice. The problem appeared on 9 March 2025. I reset Chromecast to factory settings, then manually changed the date on my phone to 8 March, chromecast updated, then returned the date to the automatic date and time settings. Now everything works.
JeanPhilippe55
Bonjour
Ou en es le correctif pour ceux encore bloqué par la réinitialisation ?
Littledoll0
What can i do if the device is showing startup issues
Glo3
Pls hurry and fixx
Janete
Sem saber restaurei, e agora faço o que?
Elaine10
Tem previsão pra esse problema ser resolvido?
cupyblon
following
AKdhdhhdjjj
My Google nest isn’t connected and I am having trouble setting it up again connecting it to my Wi-Fi. This is very annoying - Why aren’t there more clear instructions on what exactly to do?
Gabri1972
purtroppo ho resettato il Chrome cast, , Avvisami per gli aggiornamenti da inviare in questo caso
The solution is to change the date on your phone (in the settings). I set it to March 3, 2025. Then open the Google Home app again, and the setup should work without any problems.
Ayoze
Llevo una semana sin conseguir configurar mi Chromecast, ya que restablecí los datos de fábrica, dado que no me permitía enviar el contenido desde el móvil desde hace una semana.
Nenequinha27
Oi, eu resetei o meu antes de saber destes problemas, achei que era o meu aparelho que estava com problemas, ainda não consegui arrumar, assim que possível passar informações de como fazer para ele voltar a funcionar, obrigada.
Peaceman
Still nothing working
Maloro
Quiero una solución
Hiren1977
When will the update be out to resolve the issues with Chromecast?
It's been over one week now!
rossanasanchez
Cuando se restablecerá ??
Osso
I have reset my Chromecast 2, I will appreciate your instructions to solve the problem
Claudi83
Hey, then you're in the same situation as me. I also reset it to factory settings. So the Google update doesn't help because it's no longer connected to the internet. Connect the Chromecast as usual, and you should be prompted to install the Google Home app on your phone to start the setup. But that always failed, and the authentication failed. The solution is to change the date on your phone (in the settings). I set it to March 3, 2025. Then open the Google Home app again and the setup should work without any problems. After that, you can change your phone date again. I hope it works for you as it did for me. Best regards, C. Flesch
DDT1
Hello, is the problem solved ?
Pip_pill
Help.....
6 Devices are going crazy plexamp will not recognise,  media monkey will play , some will not stay awake...
Chromecast Audio!!!!!!
rossanasanchez
Cuando van a arreglar en qué momento??
mlherr
Monday, 3/17. I still don't have my Chromecast Audio.
Mastristediana
Mine worked last week thanks to a comment I read shoot I should have remembered it but huge thanks fixed it for me I was one of those who factory reset mine not once but twice … basically go to your device time to march 8th then set up your device and then it will update and then just go back to normal and you are set
