GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,159 REPLIES 16,159
Amedee
Bonjour, il est vrai que l’on se sent un peu seuls devant ce problème !
Que alguien me diga q hago no puedo conectar el chromecast
Chartz
Bonjour,
Oui on voit à nouveau le Chromecast Audio si on revient au 8/03 mais il disparaît à nouveau lorsque la date est celle d’aujourd’hui. Donc ça ne marche pas.
I can see the Chromecast in Google Home when I change the date to, say, March 8th but it disappears again when I set back to today’s date. So the ‘fix’ isn’t one.
Estaremos aguardando instruções.
How will I know when a fix has been msgs for those of us who did a factory reset?
You just need to set your device that connects to your chromecast back in time.
I have put my Phone back to a date before the problem and in google home I added the chromecast again.
So now it's there again, can't stream but ready to reeive the update from google.
I did same Managed to add Chromecast...it  Conects to wifi I can see the pictures changing BUT unable to send content from mobile It's not recognizing the device conection Any clue?
je viens de faire l'opération de réinitialisation en mettant la date du 6 mars sur mon smartphone et ça a marché. j'ai les images de google et il ne reconnait pas la connexion de l'appareil. j'attends donc la mise à jour
Bonjour, ton smartphone reste donc bloqué à une mauvaise heure ?
je n’arrive plus moi à relier mon smartphone au chrome cast
MariHN
Everyone says this, but I’ve tried more than once, without luck
Gita
How do I do both things.?
Azim12
YouTube can cast to the device after it shows up on Google Home.  However, you can't cast from Chrome!
DonnaH
This is also my question
how will you contact us with the fix.  I did factory reset it and it won't connect
Elizag
A mi me acaba de pasar lo mismo
I just put a comment before. You can add the chromecast and wait for an update
That's not an update!
We already knew that yesterday, after everyone had already reset their Chromecast.
Hope about a proper update and not just repetitive nonsense as you try to buy more time?
Do you have an estimated timeline for resolving the issue?
Slightly longer than a piece of string.....*
* This comment is as useful as anything received from Google
So, no real update yet.
No news about when will this be fixed, and in the meantime: "hey, you know, hold on or buy a competitor".
Awesome response.
Here's a tip: Hire people who work in PR. They can guide you to give a proper answer instead of this no-good empty answer.
Just an advice.
MPD0353
I'm giving them one more day. If not fixed I'm moving on. I pay for all my streaming services and I can't watch anything. Unacceptable really. The responses have been horrible.
I had factory reset my device already....
Does this also tie into this issue for broadcasting not working on Google Home products? https://www.googlenestcommunity.com/t5/Speakers-and-Displays/The-broadcast-function-suddenly-stopped...
it took you 72 hours to “identify” the issue? And, you continue to insult us with “do not factory reset” knowing everyone has already factory reset? How about you send everyone a new ChromeCast for the trouble, lack of communication, and missed days of streaming?
suz4
I'd like to see that. Won't happen though
FAOD
Best comment so far, **bleep** YOU GOOGLE for destroying a lot of lives with this confusion 🥵😡🤬🤯😤😩
I am sure the majority of users have already done the Factory Reset. We have these devices for many years. Factory reset is the simplest way of troubleshooting. It was the simplest way all the time before that. So, please find the solution for the devices with a factory reset
To reconnect your chromecast, you need to change the date on the device that you’re using to set up the chromecast (probably your phone). Change it to before the 9th March, I did the 7th. Then you can set the chromecast back up. Still can’t cast from it but you can set it back up and then change the date back on your phone.
I did factory reset (as we generally do during troubleshooting).
But then with your trick I am able to bring back my Chromcast back to the stage where we started facing issue. So at least one step done for me...
Now sitting with all the world who is waiting for Google to share the solution!
Thanks for this trick!!
MariHN
I’ve tried this, but it still wont let me connect my chromecast to the home app
That worked perfectly, thanks!
After recieving the update from Google, had to unplug my chromecast and plug it again the have it working… now I can cast!
That was such a logical, smart and simple solution!
Why is Google not posting it to inform about how to solve the factory reset situation?
As usual: thumbs down to companies and many kudos to conscious users!
Shabby
I did reset and removed from the home. Now I don't know hoe I'll out it back
I had already reset my device as this started a few days ago. Is there a fix for it or can I be notified when there is a fix
Chromcast isn’t working since 3 days. Offline message on Google Home. Tried all troubleshooting steps. Nothing worked. Did a factory reset prior to reading this post. How can it be fixed now???
Another person posting showed how to undo the factory reset that so many of us did since Google help told us to. You go to your phone and manually change the date back to the 8th. Then you can set up Chromecast and that undoes the factory reset apparently. It did connect Chromecast to my phone, but still can't stream because of the bug that the powers that be are 'working on' still.
Power chromecast off and on. Restart home. Worked for me
Pete90
Ciao Ma sei sicuro Anch'io ho installato l'aggiornamento ho spento Chromecast per 10/15 secondi o anche riavviato il telefono e di conseguenza la app ma ancora non si connette pur riconoscendo il dispositivo
That makes no sense, given the actual issue involves an expired certificate.
The premise is that you reset the device to a date prior to the certificate expiring, reset the date on the phone with the Home app to before the 8th and reconnect the Chromecast. This will only fix the connection issue that will allow an update, it will not allow you to actually use the Chromecast until the update is complete.
Works here now.  I change the phones date to 8 march and set up after factory reset.  Poeer off and on the chromecast and restart home and change the date back. Voila!!!
