GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,152 REPLIES 16,152
just wait, nothing to do,google has to buy and install new certificate at their server. changing date will allow you to see the HW but not use it
Dovresti cambiare la data dalle impostazioni dello smartphone,es.01/03
Yes but no internet is possible with false date , so sorry it’s help only to understand That is probably a certficate end problem or an external flag that google catch in his hand.
Feffax
Ho provato ,mi ha permesso di configurarlo ma non trasmette da smartphone a TV
where did You set the clock to March 7? What settings did You go to?
Ah yup.
Yeah one of the solutions in their troubleshooting… great 🙄
You just need to set you phone time and date to before March 9 and set it back up in Google home. I did it and and it is now ready for whatever Google throws at it.
I wish they tell those who factory reset their device, what to do next.
If you roll the date back on your phone and re-add the device in the Google Home app, it will work. There are also workarounds using third party tools that will allow you to start streaming until a fix is made. I used the workarounds in this post.
Some Reddit users have adviced to try and change the date of your phone to the 8th and then try and set up the WiFi again if you lost that with the factory reset
Vetinari
I tried that and even though I did get somewhat further in the process I still couldn't finish the setup. 2nd gen Chromecast
It worked for me, I had to be very close to the router. It's now set up but the original problem remains
Did you end up with ambient mode with a folder of random google photos, but not able to connect? If so you got as far as you can right now.
Yeah...same here, 5x.
E per chi ,non sapendo,ha resettato il Chromecast?
aspetta, doppo google ritornará con le instruzione
The have been much of update of you tube ,have lost the numbers of it, i think they believe the problem have been there , i,'m not suprice   that going wrong  , when all work fine , so dont change enything
Goggle you need to offer some kind of discount, to people who’s Chrome Cast has been turned into a brick. Since the outage is on your end.
No they don’t need to .
Prof... really? You spent ~$45 nearly 10 years ago and want to come in here with demands because you experienced a minor inconvenience to your workflow? The amount of entitlement here is astounding.
Heard. I spent a whole $24.99 on my Chromecast. And yes. It is dead. It's great that Google is trying to make it work again. But get off of it. Let people bitch if they want to bitch. Stop being condescending. Astounding.
Google search stands first.And stands last  when it comes to share these type of important updates
Emusk
A plague upon the house of Google
That part
Madoobe
Is there an expected time frame for a fix? Or should I be looking at getting an alternative?
0970708759
Is this issue got fixed? Please share the fix
還要多久啊
lol. this is the most useless and annoying message ever possible.
Thank you dear Techies for all the hard work. You are truly keeping society alive, while everyone is busy pointing the finger on you. We are Muggle, you are Hoghwarts. Thank you. Keep carrying on the fire.
Solution provided by @pmk421 for those of us who reset our devices to factory settings.
1. Change the date to March 6, 2025 (not automatically), which is earlier than the expiration date of the digital security certificate.
2. Use Google Home to manage your second-generation Chromecast until it connects to your home network. It's as if you just bought it and want to program it for use at home.
3. Wait with the device connected to your home or office Wi-Fi network until Google provides the definitive solution, which will be updating the device.
Regards.
Carlos
still no updates?!
I rely on this for any and all my needs
Please fix or replace  with  usable  alternative
Of course I used a factory reset. Up until a couple of weeks ago, that was always the first thing to do when the Chromecast was doing anything weird.
Whatever patch you make will have to work on devices that have been reset and no longer connect to the internet. At the very least we should be able to patch it using mobile data with our mobile devices.
Jon76
SAME!
I want to object to all the negative responses and praise Google for offering a solution for the >5 years old products. Yes you are right they should have thought on this failuremode when introducting the manufacturing device certificate but erros are made. They reach out to their customers and promise a solution which I think is very good for a product which costed me $4/year since I bought it in 2017
Mit der Datumsänderung auf 08.03.2025 auf Smartphone hat die Konfiguration des Chromecast funktioniert. Läuft jetzt alles wieder!
