Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-13-2025 07:31 AM
Some people have reported changing their mobile phones date to someday before 8th march 2025 helps setup/ restore device.. and then you will be in same boat as others atleast..
There is a hack on androidauthority which helps temporarily disable the authentication check causing problem with cca.
03-12-2025 06:38 AM
Same, i have done factory reset. Now what ?
03-12-2025 07:20 AM
Metti la data del cellulare al 7 marzo e istalla .Non funziona uguale pronto per un nuovo aggiornamento
03-13-2025 07:40 AM
Change your phone date to 7 march 2025, reboot and try to setup
03-12-2025 05:27 PM
Cómo?
03-12-2025 06:46 PM
The devices probably cost google around 50 cents from China. Just replace them all.
03-13-2025 04:06 AM
If there only existed a second gen Chromecast Audio... They also can re-introduce it (I'm all in for it).
03-13-2025 12:42 PM
That would be the best thing coming out of this mess.
I've been using Audios for almost a decade, I guess. I have 4 at home, another one for travelling. Best device ever. Turns an old stereo set up into something smart. Maybe that was the reason they pulled it from the market. When they discontinued the Audio, I bought some via eBay.
Let's see what happens here.
03-12-2025 08:46 PM
Me too! Ugh
03-13-2025 02:54 AM
Same
03-13-2025 06:30 AM
Very easy to get it back but still not working so it ps almost like you haven’t wasted hours resting it. Just do the Date hack described in here. I set my phone to March the 1st and ran the set up in Google home and it’s back to being on the local network showing the time and pictures. Let’s hope a fix is inbound soon.
03-13-2025 10:19 AM
Did the same thing. That was on the troubleshooting recommendations 🤦🏼♂️
03-13-2025 12:20 PM
You can re-install it by setting the date on your phone to 8th of March. That wont fix the issue with the streaming, but at least you can re-install your unit again.
03-13-2025 12:26 PM
I've done the same
03-15-2025 11:35 AM
1720199104645
Kamran
03-11-2025 04:21 PM
Really disappointed....
03-11-2025 04:31 PM
Guys a workaround has been already found... Glad we have some clever users otherwise we would be waiting for Google for ages as usual...
My gen2 chromescast is working fine again after following these steps - https://mensfeld.pl/2025/03/bringing-your-chromecast-back/
03-11-2025 04:36 PM
Rubbish. Changing the date locks the user out of Amazon Prime, Disney+, etc, subscriptions.
03-11-2025 04:41 PM - edited 03-11-2025 05:24 PM
The date rollback is only a temporary trick to get the Chromecast to reconnect. Once you've done that, you should change your phone back to the current correct date (auto)... as mentioned in the article that you didn't read.
03-11-2025 05:24 PM
It connects but then if you try to cast - it will say firmware issue
03-11-2025 05:30 PM - edited 03-11-2025 05:31 PM
Did you do the second part of the fix, using the Activity Manager app to disable Device Auth, as detailed in the article?
03-11-2025 05:47 PM
I just did it. Works like a charm. I'm back in business.
03-12-2025 05:25 AM
Exactly Connects BUT YouTube detects firmware out of date ( obsolete) so IT IS NOT WORKING
03-12-2025 04:04 AM - edited 03-12-2025 04:29 AM
03-11-2025 04:50 PM
Just change it back once the chromecast connects again as mentioned on the article...
03-12-2025 05:51 PM
If the device is able to establish a valid IP address on a home network via this method, then it is worth doing, because when Google deploys the required/fixed certificate on their server the device will pick it up when it connects to streamed services, the google server must be in that internet traffic.
03-11-2025 04:37 PM
Yup. Worked for me. I've posted that link here multiple times.
Note: that workaround is for Android devices only. Sorry, iPhone users.
03-11-2025 04:39 PM
I used this process to connect the device back to the internet, but as an Apple user, I still can't cast it. I at least fixed the factory reset, so if they deploy a fix, it will pick it up.
03-13-2025 11:15 AM
Same. Waiting for the iPhone brainiacs to kick in here…
03-11-2025 06:05 PM
Deu muito certo!!! Obrigada por compartilhar!
03-11-2025 10:30 PM
@GoogleNestTeameven some individual user provide a solution before you, get you things together with the size of your team, you should have already provided a fix a long time ago.
03-11-2025 11:19 PM
This workaround does not work for me. My google home cannot find my Chromecast. This is incredibly frustrating when I pay Google to make sure my devices work. Calling support is no help either.
03-12-2025 01:41 AM
If you reset the chromecast you have to add it back to the network I described in the post
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
In the home app of course it will not be visible as a valid chromecast but it will be visible on the network.
03-12-2025 03:05 AM
That's it we can go back to the future
03-12-2025 04:27 AM
My phone warns me that the link to download could be harmful. So I'm not convinced to try this.
03-12-2025 08:13 AM
Hey, i''ll try this... and a big thanks, and I truly hope that it works because my 5 yrs old told me this morning that he doesn't love me anymore 😢
03-12-2025 01:54 PM
THAT's a 'simple workaround'???
03-12-2025 02:32 PM - edited 03-12-2025 02:35 PM
Muito obrigada ❤️
Se eles não resolverem em uma semana, com certeza usarei esses meios alternativos, tanto o seu quanto o do outro cara, pois pelo visto, o Google é muito bom no descaso com seus consumidores.
03-11-2025 04:33 PM
Avete la mamma zccl
03-11-2025 04:34 PM
Already reset, too late. Very disappointed to Google. Unbelievable mistake, and still not fixed after one day.
