GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Cristinaferre75
Google,ya no es confiable,la aplicación dice que si no funciona lo restablezcamos de fabrica,y resulta que si lo hacemos,ya no va a servir,es una vergüenza que nos den soluciones,que no llevan a nada,no es un aparato barato por lo menos en Argentina sale unos cuantos billetes,son de verdad unos estafadores
Agostina
Chrome cast no funciona. Cuando lo arreglan?
AidanMoon
Mi Chromecast no se esta conectando y recibo un mensaje con un link, eh intentado todos los tips y nada parece funcionar.
Acastella2003
Mi dispositivo no conecta desde el domingo. Lo reseteé a condición de fabrica antes de saber que el problema era generalizado. Cómo hago para repararlo?
Buen día!... tengo el mismo problema!!.... por el momento no veo que Google haya solucionado el problema o haya dado explicaciones al respecto. 😒
Hello, I also restored it to factory settings and following the following steps I was able to reconfigure it, I managed to broadcast from the mobile to the TV again, but the image from the mobile is only partially displayed, at least I was able to reconfigure it and now I just have to wait for the update.
First of all, you need to change the date on your mobile phone to a day before March 9, 2025. From here you can reconfigure the Chromecast.
Then follow the following steps to be able to broadcast again
Fix casting from Android (GUI method)
  • Download and install an activity manager app, like the free and open-source Activity Manager app.
  • Launch the app and select Intent Launcher from the dropdown menu in the upper right corner.
  • Tap the edit icon next to the Action field and type/paste this: com.google.android.gms.cast.settings.CastSettingsCollapsingDebugAction
    • On Android 11 and below, type/paste this instead: com.google.android.gms.cast.settings.CastSettingsDebugAction
  • Leave the other fields blank, and tap the checkmark button in the lower right corner.
  • In the Cast Debug settings panel that pops up, scroll down to Connection and enable Bypass Device Auth.
This workaround forces open the Cast Debug settings page and lets you enable the Bypass Device Auth option (i.e., it allows you to turn off device authentication), partially fixing the issue. You should now be able to cast from apps, and the Google Home app should also partially work.
  • Desde el domingo  de marzo 2025 no funciona mi Chromecast
MonicaFrancho
Estou a 2 dias tentando entrar em contato com o suporte, mas estava congestionado! Deveriam mandar um aviso no Google home sobre o ocorrido para que não fiquemos preso a isso
TiredTrying
This is terrible. I factory reset mine several times because it wasn't working. Now what?
mongoose5271
HA! Literally any response sooner than the many, many hours you **bleep** waffles took before you even acknowledged the problem would've been better than this bull**bleep**. Also...the "Please don't factory reset your device" plea was a very nice touch, considering it's one of the very first things mentioned in the troubleshooting guide. Well done! It's almost as if the powers that be had a brainstorm session on the best way to piss off a huge percentage of your customers and push them to your competitors. Chromecasts are in the trash, speeding to my local phone outlet to turn in my brand new Pixel 9 Pro for something un-Google and uninstalling  any Google app I'm able. Nice job, **bleep**nuts....
EvdM
Google...? Please share an update....don't leave your customers sitting in the dark
Pamelacorcoran
Please keep me posted as my dongle just stopped working. It’s unfair they we got in first to by them and we are getting penalised
Alberto_Madrid
Se estima algun plazo de resolución referente a Chromecast? Soy junto con miles de usuarios que restablecieron el dispositivo a modo fábrica.
Tampoco entiendo que fuera un inconveniente porque antes del fallo se podía realizar sin problema.
Rb15
Any updates on the Chromecast? It's such an inconvenience for us that rely on this device. It's been almost 4 days now 😪
Mokatrinh
I hope soon
WillShee
Terrible response from a terrible company. Google should be ashamed of themselves.
Lioforest
Too late for the reset…, for one of our two chromecast
waiting for the solution
Jonalyn
Hello. When this can be resolve? It’s been since Sunday I can’t use my chrome. Please fix thi asap. I was panicking I thought its broken or something happened.
joaop
I am affected to. Thanks for the update. Strated troubleshooting before knowing it was global... and tried to factory reset 😞
Anders3
I have third generation with this software version
Chromecast (3rd gen)1.56. 291998
And although i managed to factory reset it before configuration ( i just bought it) name it and add it to my home in Google Home app , i cannot cast to it. Just like what you are describing gen 2 problems. So i guess its not only gen 2 and cc Audio?
I hope you will update gen 3 aswell
Ed2025
Já estamos a 4 dias sem uma solução, qual o posicionamento sobre está problema ?
Mariohuana1983
Hi. The Chromecast is discovered in the network. But there is connection failure in the end. It is not the router since I get the same result with hotspot. Please help
Understand that Google is not better than any ordinary company who try to exploit people. Money is ultimately supreme to everyone.. That's what President Trump says.Chinees goods are  now seems better option as they are cheap. We will not frustrate if they stop support or the product stops functioning. The most frustrating thing is betrayal. That's what Google did on Chromecast gen 2 . They killed the trust.
Now I will think twice before buying google product
Saabdala
Desde domingo, aguardando, quando tentei todo tipo de correção e instrução, inclusive do próprio suporte, antes que eles dessem notícia, claro, sem dizer que era por puro descaso da empresa.  Quarta-feira, já sabemos o que rolou em relação às autenticações expiradas e até agora nada de resolverem e se explicarem.
Diux
Unfortunately,  I performed factory reset. I'm waiting for your instructions.  Best regards
Diegogonzalez
Tengo el Chromecast 2 no funciona. Le hice reinicio de fábrica. No aparecía en ese entonces la advertencia de Google de no realizarlo
Necesito una solución a la brevedad .
Gracias
Camuc
We all know that Chromecasts stopped working on the 9th of March because Google forgot to push an update to replace an expiring certificate on the device. There are 3 ways to go about this problem, yet Google has not implemented any.
1) Those Chromecasts that have not been reset to factory default can still connect to the internet and an update should be available directly from Google. Why hasn't Google pushed the update on them yet? This would likely fix about 50% of the devices out there.
2 and 3 [one for Android and one for iOS] ) Users who performed a factory reset can still setup the device by changing the date on their phone to before the 9th of March, and they will get to the point of configuring the Chromecast's wifi connection. At this point their phone will lose connection with the Chromecast because it will switch from Bluetooth to Wifi, but at least the Chromecast should have access to the internet (if so, the date displayed on the TV by the Chromecast will be correct).
Steps 2 and 3 can be complicated for users with little technical knowledge, but this should save a lot of devices from being "bricked" for good, and should allow Google to push some update on the device (see point 1).
So, why hasn't this happened yet? Why hasn't Google even posted step 2 and 3 officially to any channel to give people something to start working with? Any chance that this has to do with the new $99 Google streamer?
Disidra
Gracias, lo he intentado, y cuando he cambiado de fecha entonces me ha podido reconocer el Chromecast. Lo he restablecido de fabrica xq no vi antes tu post. Pero ni aún asi consigo q establezca conexion. Ufff a ver si lanzan una actualización como toca. Hay q fyfhhddhisgs (es un taco) sino.
RobBerko
I've already factory reset my chromecast. Please send instructions on how to setup my device now.
Thank you,
-Rob Berkowitz
e: #
Caduser
Here is the latest from Google on the problem:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
Apparently they are working on it.
Saabdala
Aparentemente foi retirado do ar. Essa página não foi encontrada.
Daniela0
What did it say? It says url is not working
ChabazB
Hello everyone. I read a couple of post and many have similar issues I have. My Google Chromecast is not working... Tried as well to reboot, get through the motion up until the end when get the mess on screen S9M9 and confirm the nothing but the message saying the Chromecast cannot be authenticated... I know this year it will stop receiving updates but it's not until August. It really sucks cause it's a great little device and I wish it could give me a little while longer of life. It seems nobody got an answer about this problem??? I cross my fingers for a solution cause the new Chromecast is unavailable (out of stock) where I live(Quebec/Canada) and I don't know if it would work the same ???
POK
Been using this Chrome cast for years.   Suddenly it's not 'authenticating'.  All wifi etc been triple checked.
Please advise
TaisR
Estou sem TV desde do dia 09/03 devido essa pane no app Google home e  no aparelho chromecast. Se dizem tão inovadores e tecnológicos que não fizeram atualização do sistema.
Ou é mais uma jogada para forçar a comprar um novo produto.
