GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,122 REPLIES 16,122
Hola, a mi me pasó lo mismo. Están trabajando en el tema y resta esperar...
We also reset per the site instructions and now it won't authenticate
Elle26
The latest message from Google asks not to factory reset, and that they are working on a fix asap.
Yeah too bad their troubleshooting site says to do so.... That's why so many people have done that
That’s why I did it 😕
🙋🏻‍♂️same..
Dgedaz
... and I did the same! 😬🤬
AxelAgain
Same... better just roll out a replacement to me at this point google
Change the date of your phone to one year back and then try, and later once connected you can change your date to latest.
raulfergaeza
But the first thing that is said to be done when the chromecast stops working is to reset it. Yesterday I spent 2 hours resetting and trying to configure it again but it was impossible. Please comment if there is a solution or if we have to look for alternatives because I am paying max, amazon, netflix... and now I can't watch them.
Right? And they waited 24 hours to tell us NOT to.
Yes, too late!!! I have reset it 5 times in the last 24 hours kkkkkkkkk
Jajaja estamos iguales
Eu perdi as contas de todas as vezes q reinicie ele nessas 24 hs kk
Me to !
Cele
Anche io
Same here... smfh
My husband and I wasted a whole evening trying to figure out the problem. It ended in frustration! I ended up resetting it. Now today told not to!,
Anonymous
Not applicable
Me too. Very frustratrating😡
Please try to reset the phone date to an old date like 6th March and try to connect again. It will connect do Chromecast but not able to cast since the issue is still there from which needs to solve by Google Team
Elle26
Exactly! Rather infuriating isn't it! Just a couple of days ago I switched to YouTube premium; I also pay for Netflix & watch all my news etc via TVondemand.
I made the change on android device of date to 7 march I reconnected the Chromecast to the WiFi network now when I cast I have a firmware issue
Joe36
I could re install it by changing the date. But still not connecting
Once you've re-added the device by rolling the date back, there are additional steps required to restore Gen2 casting from an Android device. It's all detailed here in this workaround:
https://mensfeld.pl/2025/03/bringing-your-chromecast-back/
no solution yet
Exactly!! I have 2 devices, one in my room and the other in my living room. The one on the living room is working perfectly,  so I assumed the problem was on the device in my room, so I reseted it. Thank god I found this page, otherwise i would have lost so much time trying to figures this out.
If you have an HDMI port on your laptop, you can bring Max, Amazon, Netflix…up on your browser and hook your laptop up to your TV with an HDMI cable.
I don't have a laptop
mckoy
kindly send me instruction because i already reset it cause whenever i try to connect it its showing cannot aunthenticate the chromecast...thanks
Jgr77
Set back the date to before 8 march on your device. Then you can reconnect your cromecast. It will not be able to stream before the fix comes, but it will be able to receive the fix.
Fran1255
It worked thanks 🙏
Hoe did you reset the date?
sherik
What did setting the date back accomplish in terms of functionality?
Slavitch
Nothing it just keeps it from getting bricked.
Hoe do I reset date?
Go to settings, General, scroll down to date and time, turn off Set Automatically and change date
Lily8
Where do you find settings to change date?
Lily8
I found it. It is the Mobile phone settings
Sofos
Inställningar var?
van_rijn
Thank you so much! It worked. Let"s hope the fix will come soon.
