Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-09-2025 06:38 PM
Not working in Australia either
03-09-2025 06:39 PM
Same thing in Uruguay. Today my 2 chromecasts do not connect.
03-09-2025 06:41 PM
I'm having the same issue. Even after factory reset.
03-09-2025 06:42 PM
Same, Pennsylvania.
03-09-2025 06:42 PM
I no longer able to connect to my Chromecast it states that I need to authenticate my Chromecast no matter what I do I cannot accomplish anything I'm completely disconnected from my system what is going on with Google I can't take it anymore
somebody please help
03-09-2025 06:42 PM
Error de autentificacion también!
03-09-2025 06:43 PM
I experienced intermittent casting the last few days. I did a factory reset and now it cannot authenticate when setting up.
03-09-2025 06:45 PM
Bye google!
03-09-2025 06:53 PM
Je suis du Canada au Québec et cet après midi mon chromecast a planté et impossible de le faire fonctionner car "impossible d'authentifier votre chromecast" ... Même après réinitialisation etc... Et la je vois que c'est un problème mondiale... Bizarre, à suivre
03-09-2025 06:54 PM
The same problem here in japan
03-09-2025 06:56 PM
Same issue
03-09-2025 07:10 PM
Same 😐
03-09-2025 07:11 PM
Something happen with firmware or what ? , it also happen in Indonesia, can not connect
03-09-2025 07:12 PM
Same here
03-09-2025 07:13 PM
I decided to setup my Gen2 today on one of my old tv's and faced this problem too. Just my luck that this issue seems to have happened today of all days! xD
For more clarity, here is a reddit post that can clarify that Google seems to be working on it:
https://www.reddit.com/r/Chromecast/comments/1j7caui/did_google_just_brick_the_2nd_gen_chromecast/
03-09-2025 07:14 PM
I believe that google implemented a Chromecast update but forgot to mention it
03-09-2025 07:14 PM
So it's a International issues happen, and still no solution from Google support ?
03-09-2025 07:19 PM
Having the same issue...really hope this isn't a matter of lost support and expecting us to fork out for another newer unit...
03-09-2025 07:19 PM
Same issue here. It was working fine in the morning. They should at least inform the users about the new changes.
03-09-2025 07:23 PM
Same here in Argentina
03-09-2025 07:25 PM
I'm having this same issue, couldn't cast to my Chromecast all day, did a factory reset, now it can't authenticate.
03-09-2025 07:28 PM
Steps to get a faster fix for chromecast issue:
I you have a pixel device you get priority support. Go to your settings on phone.
-> Tips and support (prob last thing in settings)
-> Contact us
-> (subject) chromecast not connecting
-> when asked what device, select your phone model.
-> request a call back
-> when they call, tell them you have tried resetting etc it's a world wide problem, everyone around the world is reporting on Google forums, reddit etc that chromecast are off line and won't connect etc.
The person you speak to will email the Google chromecast team with your email address etc and they have to get back to you within 24 hours.
03-09-2025 07:30 PM
Same issue, wasted time rebooting router and factory setting chromecast multiple times.
03-09-2025 07:31 PM
Having the same issue since this morning.
03-09-2025 07:32 PM
Same- 2nd Gen that has worked fine for close to 10 yrs stopped linking to my Home, and now can't authenticate following a factory reset
03-09-2025 07:33 PM
I have a Gen2 and cannot authenticate. Help
03-09-2025 07:36 PM
Same. Worked fine this morning, then this afternoon it stopped playing anything. Tried a factory reset and now getting an authentication error
03-09-2025 07:38 PM
Me pasa lo mismo y lo quise reinstalas y da error de aitenticacion. Que pasa con este fallo general? Lo van a arreglar?
03-09-2025 07:41 PM
Happening in Australia as well.
03-14-2025 08:44 PM
Australia: Yay🌼, my Chromecast Gen 2 is alive again!!! I just completed the date wind back to 7 March 2025 in Settings on my Nokia phone (Android Version 14), ran Google Home to reconnect my Chromecast to my WIfi and dumb TV, saw an update progress bar on the TV (never seen before). Google home: "set up says it has a problem, update is taking longer than expected". I wait 5 minutes no change, enter Help Centre none of the options fit me, exit Setup and put the date back to automatic. Open Google Home again and my Chromecast connected to my dumb TV is listed 👋. Casting via my phone is working. 😺
03-09-2025 07:41 PM
Same here. I am from Brazil.
03-09-2025 07:48 PM
fix it
03-09-2025 07:48 PM
Looks like chromecast stop there services.
03-09-2025 07:50 PM
Same for me! Stopped working. After reboot, reset and even changing display device the chromecast couldn't be added back because of an authentication error...
03-09-2025 07:58 PM
Same problem here, cannot authenticate. Tried factory reset and everything, nothing seems to work. I have a Chromecast 2 gen
03-09-2025 07:59 PM
Same in my case. I get this....
We couldn't authenticate your
Chromecast.
03-09-2025 08:00 PM
Same here in California.
03-09-2025 08:04 PM
Me pasa lo mismo en mis 3 Chromecast mismo error. Mal Google.
03-09-2025 08:09 PM - edited 03-09-2025 08:16 PM
Same here from Las Vegas, NV. I have my product Serial Number. I've rebooted 5 times to no avaiil. Someone mentioned to me that Google is deactivating the Chromecast devices of people who've been critical of Israel on Youtube or otherwise. Let me know what you think.
03-09-2025 08:11 PM
Google...does not care. Have any of you received any notice from Google saying anything about this issue? Time to dump Google.
