GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Energy_ionut
Waiting for the after factory reset solution. Thousands of people reset it as per instructions provided in help center
ashleyw-forums
This is also impacting audio casting to Nvidia shield tvs so it's not just CCA and cast gen2. My entire home audio system of 9 CCA and 3 shield tvs is down.
hopefully it'll all be fixed soon so I don't have to bring out the old Squeezebox and start ripping CDs and collecting mp3s again!
KevinAtHome
Is there any location where one get status updates without being spamed with posts not helping in any way solving this issue ?
Spellbounding
How long before we see a class action lawsuit...
Beitagamonal
Lo que tenían que haber dicho antes es que no había que reestablecer el dispositivo a la configuración de fábrica, ya que, muchas veces hay que hacerlo porque se desconecta del wifi.
Ahora, necesitamos solución igual de rápido que los que no lo hayan reestablecido
jpwinkler
Of Course I did the factory reset as the first thing. That is what you do when devices stop responding.
But I also did the re-start by setting system data back to March 8th. Anyway awaiting your fix. I a very nice device... when it works.
Blaumar
I just tried wit the Link https://mensfeld.pl/2025/03/bringing-your-chromecast-back/
Some colleague added to the chat
It worked!!!!
Abramo
Naturalmente ho ripristinato, spero in una vostra celere risoluzione
Mary64
It shows me L4M6 but nothing on the cellphone
Joshpeace177
Hi I factory reset my device hope you can help with a fix please thanks
josh
raymondlopez896
Please fix asap
AlienElAlien
Increíble esta situación viniendo de Google, que vergüenza como se está comunicando. Resulta que lo hace todo por twitter, si no tienes twitter y no quieres tenerlo no te enteras de que sucede con tus aparatos...
Que bajón está pegando google, ya ni si quiera uso chrome por su política anti adblock y parece que todo va a peor con el tiempo.
Cassidygillette
Has this been resolved as I am still unable to connect my device
drgm
Already done factory reset for 2nd Generation Chromecast. Pls solve the security certificate issue and also instruct on how to recognise the device if factory reset is done. 3 days is a lit of time.
Thank you
Tarragona
En España, cuando volverá a funcionar el chromecast si lo he dejado de fabrica?
SylviaHamilton
I factory reset my device before reading this memo. How long should I wait for the update? I haven't been able to watch or stream anything to TV for 2 days now.
Ron51
I can’t get my wifi to connect through my chromecast to my tv. Is that my chromecast problem?
Erkr
If Google works with scrum/sprints it will at least take one sprint ☺️
ozymandias45
ça commence à être long ...google faut se reveiller , la technicité de votre marque est en jeu , ne soyez pas que des vendeurs de trucs cools , faites marcher vos trucs cools .
KazHazmat
So you waited almost a week to tell people to not factory reset, when you otherwise encourage factory resets in case of any issue? The comms on this situation have been very poor and disappointing. I, like many others, didn't even receive an email.
Exactly. This is unprofessional by Google, to let us all know after the event.
zzizyung
I already did factory reset because when I tried to fix it this post wasn't here but Google page guided me to to do factory reset so I fellow exactly what is written here. Ant now you telling me to not to factory reset, too late now, you should have posted this before it's coming.
Martin7477
Any updates when you have a solution this issue? Waiting for 5 days and still no progress or update?
Nexus6x
So now that majority of us has reset our devices,what now!?
Angela_Duran_
O problema é que a orientação de não restaurar o dispositivo veio tarde demais para muitos de nós. E agora? Quando compramos, não especificava "data de validade". Cabe processo?
Suzieq25
Any more updates on how to fix it
They said we have to wait.
BusterC
when
oimikey
Why is it taking so long to get this fixed?
Seignoux
And if i did ?
luizinhoez
No desespero restaurei o meu chomecast 2 para configuração de fabrica, perdi o aparelho?
Chitta
My cromecast allready factory reset.the what next
Willeke
But what is the solution?
Chitta
My cromecast allready factory reset.the how I manage to install the device
Danjalves
I have three that are used daily. Any updates. Not like a Google product to fail like this with no customer support. Very disappointing
Natashamug
any updates?
Kaggy
As Google has not answered in 3/4 days I think I may have to purchase a different casting tool
Hussna91
Hey! When is the issue going to be resolved?
Ellz
when will this be solved by ?
Lottie87
I've already did the factory reset, how do I solve it now?
