GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,145 REPLIES 16,145
Katiehu
Same here! Hope we can get ours working again. It’s so frustrating
Thank you
When you say must be connected do you mean I need to keep it plugged in and the power on for the next few days?!
No i think they actually mean the chromecaster must be connected to the wifi or in other words it must be set up
Kebab1
Thats right.
Is anyone able to connect to their cc to wifi though? Since the issue started my device shows as offline and can't be connected... doesn't matter what I do i can't get it to connect... so does that mean I won't get the fix ?
I'm connected to wi-fi, you can do it through the app, unless you did a factory reset then you should do the date change thing and it should connect
Nope still awaiting for Google support team to wake up and upload a system fix. Guess they want everyone to eventually give up and go but a new Chromecast
Yes thats the only way you can get the new firware.
Not according to others, they suggest it means that Chromecast just needs to be set up and connected to wi-fi
I almost bought a Roku unit last evening, but didn't because Walmart was out.
2025...🙇🏻‍♂️
Yo lo restaure de fabrica porque no me iva y ahora no me deja configurarlo cuando sabré que ya se puede?
No caso de quem fez o reset?
Good to hear that Google is starting to roll out a fix. But... What do you mean by "your device must be connected to receive the update"???. Surely one of the major features of the fault is that all affected Chromecasts are now unable to connect to the internet? I didn't do a factory reset (like almost everyone else!), but my Chromecast connected TVs have been stubbornly showing as "offline" for the past 4 days! How do we magically get them to connect so that the "fix" can be initiated? More info please...
Chromecast being offline was not the issue. Devices refusing to cast to it was.
Anonymous
Not applicable
Fix was found by the community for those of us who factory reset. Simply set the date on your device to March 8th or earlier in your settings, then do your Chromecast setup through Google home. Hope it works for you!
This did not work for me
Worked 🙌🏼  thank you!
Sejer
For me to get it to work, I had to restart my phone after setting the date on my mobile phone to a date prior to march 8th. Anyway thanks a bundle. Now I was able to complete the configuration of the chromecast that I had not only reset but also removed as a device in Google Home. And as an extra bonus, the second one all of a sudden shows as online again in Google Home. What’s not to like. Now just eagerly waiting for the update that will allow me to also actually cast something 😉
helsbels82
Thanks I'll give this a go 👍🏻
My thoughts exactly, same issue. It’s connected cos the screensaver changes as it always does but CC2 is not showing on my wifi or Bluetooth as available. On Google Home CC2  is appearing offline. I did a factory reset but changed the date and added it back on wifi successfully a few days ago. Not sure why! Will Googlenest find a way to magically connect when Google Home can’t talk to it??? Amazon Fire Stick or HDMI cable to mini laptop may be the answer arrrrgggggghhhh!!!!!
it is actually connected to the Internet but the bug preventing the device to cast I guess!
I'm confused about this too... how do you connect when part of the problem is not being able to connect ??
I'm guessing that Chromecast devices use many different types of connections. The first is a connection to the Internet which depends only on the Chromecast having your router's WiFi name and password stored. All other types of connections run on top of this one. Another seems to be the connection between the device you cast from (phone, computer, etc.) and your Chromecast device. This connection runs on top of the previously mentioned connection to your router and the Internet.  This connection requires a valid chain of secret keys on the Chromecast device to be valid. One certificate (key in simpler terms) in the middle of the chain has expired (it was only given 10 years of validity) causing the connection to fail. So now your phone or computer and likely certain services on Google's or others' servers refuse to talk to your Chromecast device.
Note: I used the term 'secret keys' in place of a more accurate term as Google seems to wish to filter the word. Hint: (building in a graveyard with coffins stored permanently, usually for a single important family)ographic
Jon
Ya hay solucion para quienes reiniciamos el equipo antes dd saber que se trataba de un problema global?
Haz la prueba de cambiar la fecha en tu teléfono manualmente a marzo 8 2025 (anterior a la fecha del problema) y desde la app de Home adiciona dispositivo, cuando te pida clave del wifi procura ingresarla manualmente y a todas las demas preguntas responde "no por ahora", y asi logre que el chromecast se conecte a Internet, ya se ve el reloj con hora actualizada por tanto tiene conexión, ya transmitir videos si no se puede hasta que no llegue el parche de corrección de parte de Google, pero por lo menos ya esta en línea para recibirlo.
Still waiting, 4 days in. Where is DOGE to deal with this incompency?
Hi It's hours and my Google Chrome is not working. Almost almost two weeks. I did update.
JJ-27
le temps passe vite pour vous ! c’est depuis le 9 mars et donc pas encore 1 semaine
Je vois remercie de m'informer de la résolution de ce problème, j'ai un Chromecast 2 et impossible de le connecter. J'ai fait un reset usine !
I was able to complete the setup when I did a factory reset. Simply manually set the date of your device(where the google home app is connecting from such as phone or tablet) manually to March 1st and complete the setup. Afterwards set date back to Auto. Casting will still not work but adleast the factory reset is undone and setup is complete awaiting the fix from Google.
hope this was helpful.
Pas réussi...
Is it true that Google company is sinking?
O único problema que devido ao problema fiz a compra de firetv porque não poderia esperar pela solução do problema
Fico muito chateada com isso porque a muito anos uso o Chromecast
Hola! Yo restablecí la configuración de fábrica, cuando leí que no se recomendaba puse el móvil a fecha antes del 9 de marzo y pude volver a configurar el Chromecast. Sabéis si eso es suficiente para que se actualice cuando saquéis el nuevo software??
Bonjour
Malheureusement j ai fait un reset merci de me transmettre la procédure
Bonne soirée
HELLO . THE FAULT PRESENTED HAS CAUSE A BIG PROBLEM SINCE WE DO NOT HAVE A MUSIC IN OUR WORKPLACE( SPORT CENTER) DUE THIS FAULT. WE NEED IT RESOLVED URGENTLY
Bull**bleep**
Chromecast Audio is showing online again in the Google Home app, but my Plex server still can't connect, so the fix doesn't seem to have helped.
