GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
Ma come è possibile modificare la data dopo aver resettato tutto?
LexiC
Are there any updates yet on this @GoogleNestTeam
Bas3
Hier de workaround/fix om je chromecast v2 weer te laten werken, voor de Nederlanders onder ons, die Android gebruiken:
https://www.googlenestcommunity.com/t5/Streaming/Hoe-je-de-ChromeCast-2e-Editie-weer-werkend-krijgt/...
KoB_2025
Not only issue with Android, also with iOS and Chromecast (2nd gen).
Maddddddd
i’m so mad. I spent my entire evening trying to configure and  troobleshoot my entire network before i found this post. So much time wasted around the world.
Same!! Very frustrating!!!
mircogaggi
ciao
ho già ripristinato le condizioni di fabbrica.
attendo istruzioni su cosa fare per risolvere il problema di autenticazione. grazie
Valentina82
Anche in Italia. Stesso problema. Ovviamente si è subito fatto ciò che dite di non fare, il reset. Attendiamo soluzione
ignorp
Frig I just saw this and have factory reset all my devises!!! What my next move?
Hellowin
Factory reset done in the first 10mins of 'not working time' as many other users of the device i guess. Waiting for instructions to get the device i paid back to its funcionality.
IreneM
Same here and of corse after several attempts to restart my phone, my router and my tv I pushed the reset button as mentioned everywhere. Please provide us with instructions to fix this asap. Simply embarassing Google!
Thurston11
You waited 20ish hours after the problem started to give the advice "Do not factory reset your device" 🤔🙄🤷‍♀️🤦‍♀️
DrCharles
Any news on the fix for this Chromecast issue yet, please?
cam3329
oops already reset it lol
Brekelenkam
Well, I did factory reset it. What the hell do I do now?
Dado1979
Purtroppo da ieri sera anche io ho lo stesso problema... mi viene naturale da rispondervi che La prima cosa che viene in mente è riavviare il dispositivo, la seconda il router e la terza resettare alle impostazioni di fabbrica per la riconfigurazione... solo dopo questi passaggi il 99% degli utenti cercano risposte nel forum quindi immagino che il problema deve essere risolto proprio per la maggioranza delle persone che hanno già resettato ad impostazioni di fabbrica.... State bloccando persone che non hanno smart TV!! Siamo fuori dal mondo 😞
Amber_R
When will there be a new update about this problem?
Emilie1
I will need help after factory resetting my device.
Derik64
factory resetting does not work, you have to wait for the fix from googe. Check out the pinned thread on top.
Mleyson
Anxiously awaiting the fix of the Google Chromecast devices. I love them and use them all the time and would like to be able to continue using my multiple Google Chromecast devices. This is my vote against planned Obsolescence.
Ghoul
What if i already make a factory reset ?!!
Almenwow
A mí también me pasa lo mismo, no puede autenticar el dispositivo.
Hay alguna solución?
KarinaG
Thank you so much for this update. Let us know what to do asap, please. I don't want to buy a new one, this one worked perfectly well until yesterday when it just stopped casting. Thanks in advance!
KevinAtHome
Samsung XCOVER with Android 8.
First, I set the date to end of february so I could restore the connection of the Chromecast Audio by Bluetooth to my WLAN. Installation ended by a menu that wants to connect it to my google account, so I aborted it here - device was shown "half" in Google Home.
Then I tried this "Fix casting from Android (GUI method)" Reddit hint with the "Activity Manager" app and set CastSettingsCollapsingDebugAction for Android 8.
Now I started Audials and could stream some Internet radio and even set the volume.
It's just a workaround as the device's attributes cannot be set but...it's a workaround !
EQOY381
Hi  ,   We have performed a factory reset on the device.
Cerro
Buenas tardes como todos los usuarios tmb reinicie de fabrica mi chromecast ya que nadie informo de un problema general quería saber colo poner el código... la app de home para chromecast toma mi dispositivo desde la tele tengo el código para poder pero al momento de ver pantalla y escribirlo aparece q no puede continuar que me dirija a help
Catvader
Me pasa lo mismo y no encuentro forma humana de arreglarlo. Obsolescencia programada. Ni un producto google mas
Me pasa lo mismo me sale el codigo en la tv pero no deja seguir avanzando desde ayer intentando y no hay caso
KevinAtHome
Edit: after the device was "half" detected in Google Home again, before the "Fix casting..." I reset the date to today, otherwise I got errors from my apps.
Jayrup
Where will we find the updated information?
Rene11
Y que hacemos los que si hemos reiniciado el dispositivo? Debemos tirarlo a el cesto de la basura? Me parece de muy mal gusto esta situación de una empresa tan prestigiosa, Resuelvan el problema, ya que al comprar su producto, jamas pense que me daria problemas.
WillCroxford
I reset my Chromecast Audio then couldn't add it back in. I set my phone's date to 3rd March and then I could add it back in but it's still not working. So I'm back to square one.
Retep1
How long do we wait? How will you let us know?
Ntania
Καλημέρα! Προσπαθώ να συνδεθώ από το iPhone μου όπως κάθε μέρα και μου βγάζει το παρακάτω μήνυμα: Δεν ήταν δυνατή η επαλήθευση της συσκευής. Αυτο μπορεί να οφείλεται σε μη ενημερωμένο υλικολογισμικό συσκευής.
AndyHA
Hey Google, for you to know! Even after a factory reset (an operation that was done by the majority of people impacted yesterday), it is possible to re-establish connectivity between the device and the internet., both with changing the system date on an android client app and without. Streaming to the device is still impossible though. When you use the date trick the device is also enlisted in the Google home app, while without the date trick the device is connected to WiFi but it does not appear in Google Home. In both cases it is impossible to change the device settings. Hope this can help with your testing and delivery of a fix. Please keep in mind that majority of people did a factory reset.
thanks
PauloC
Hola gente, tuve problemas de conexión con mi chromecast de 2da generación, no podía conectar ninguna plataforma, así que lo reinicié, y mk teléfono Android lo reconoce, sin embargo, al llegar a la parte en la que te da el código, me salta el mensaje de "No se pudo establecer comunicación con tu chromecast", ya lo reinicié varias veces, al teléfono y al romper también, vacíe el caché de Google Home, y nada, alguna sugerencia?
PauloC
"Router"
caeds3401
Parou de funcionar ontem, no começo era rede sem segurança para uso do chromecast, desinstalei todas as casas e repete o chromecast e depois a mesma coisa no meu celular, fiz todo o processo de configuração e na hora de colocar o código que apareceu na tv, veio outra mensagem (NÃO FOI POSSÍVEL AUTENTICAR O CHROMECAST) não sei mais o que fazer, se alguém puder a resolver essa situação eu agradeço.
Alvino
Por enquanto não há o que fazer, apenas aguardar uma atualização que está em andamento pelo Google.
Me ha pasado lo mismo. Soy incapaz de volver a configurarlo. No encuentro solución alguna y Google tampoco ayuda mucho...
