GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Agradezco escriban también en español.
ya probé con los 2 chromecast que tengo en mi casa y ninguno funciona. Uno fue restablecido y el otro no. No me han dado ninguna solución.
El mio ahora "no puede ser autenticado"... 😒😒😒
It WORKED!
I had factory rest both of my chromecasts...
so what I did today... was i set the date on my phone to February 25th 2025. Then I connected my chromecasts to power, an my tv's hdmi port. Went to Google Home on my phone, and processed to setup the chromecast device. It went ghru some setups, and reboots... then I was able to name it, and try and link it with google account (it failed) itvtried to link other to other services like audo, and video... they all failed.  Then it showed me an image as a wallpaper... at this point i set the date on my phone back to being managed by my cell provider. Shut down the Google Home App, and restarted it. Now my chromcasts show up! And im able to cast to them!
Não estou conseguindo acessar o Chromecat
Voltei ao meu ao padrão de fábrica pois só soube do erro bem depois. Por favor, quero usar meu cast novamente
Tem previsão?
This is garbage.
years working fine and suddenly interrupted? Surely you’re pushing customers to get new products and not being diligent with your “problems”
20250314 @2313 The issue appears to be resolved; Chromecast Gen2 casting again.
Restaurei a configuração de fabrica, agora quando ele vai configurar está com erro de comunicação, o que eu faço?
This worked for my reset Chromecast:
"For all the factory reset people who are freaking out and asking "what do I do now?", this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started pushing out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 7 or earlier.
2) Use the Google Home app to re-setup your Chromecast. You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Also, you can change your phone's date/time setting back to Auto now.
3) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Note: Supposedly it's being done as a "phased rollout", so it could take as long as several days for the firmware update to hit your Chromecast."
Anonymous
Not applicable
meus 4 voltaram a funcionar entrou uma nova atualização e resolveu o problema, os que eu já tinha resetado , tive que fazer aquele processo de voltar a data pro dia 08/03 e conectou no wifi e em seguida entrou a atualização e voltaram todos a funcionar , maravilha
Soluciones por favor ¡!!
What do you mean by 'Your device must be connected to receive the update.' Does this mean I have to leave my tablet on all the time or do you mean the chrome cast connected - I am not tech savvy,
Thanks
O meu não quer configurar mais
My chromecast works after update now👍🏻👍🏻
Lo normal era reiniciarlo, es como cuando el Internet te falla, reinicias. Así que porfavor arreglen que eso quede asap!!
ejmata305
Incorrect!
Eu redefini para configuração de fabrica e quero uma solução
Meu chromecast não voltou a funcionar aínda.
How much longer or how much discount for a upgraded Chromecast
Why my Google speakers stopped working??
 Where do I ré-input my home network password?
This issue has been resolved on my Chromecast, thx team
How much longer is this going to be???? It's been over a week now!!
If you ended up factory resetting the device here’s what you can try. Change your phone date to march 8 and try setting up your chromecast. It should work.
Hurra,
jetzt funktioniert auch der Chromcast Audio wieder der von mir auf Werkseinstellungen zurück gesetzt wurde!
1. Datum am Handy auf 06.03.2025 einstellen
2. Chromcast Audio über die Google Home APP neu einrichten und abwarten.
Bei mir hat es über Nacht gedauert jetzt läuft er wieder 🙂
How long will this take, it’s been 1 week of it not working for me now.
My chromecast seems to now be working
Solo queria contarles que hoy al encender mi tv con Chromecast (Chile), se puso a actualizar y ESTAMOS DE VUELTA!!
Todo funciona otra vez!!
I just wanted to tell you that today, my Chromecast update itself and we are FULLY WORKING!! (For reference, I live in Chile).
Please let us know if any fix come up. I have done factory reset
Please fix as soon as possible
When can we expect a fix if we have done a factory reset ?
Thank you, my Chromecast is working now.
I took the steps as advised by community and Google. I had factory reset my Chromecast when it stopped working so was not able to reconnect with it.
I changed the date on my mobile phone to 1st march and that allowed me to reinstall Chromecast on my television.
Initially nothing happened after that and I was back to where it stopped working on 7th March with Google photos on my screen but not able to connect my device.
I turned off the television and Chromecast and later turned them back on an hour later. The Chromecast automatically started updating, took a few minutes and is working now.
A re happy customer from Pakistan.
Tried this set the date back to 1st march nothing happening?
That's surprising
I presume you have factory reset your Chromecast.
So what happens when you try to reconnect to it using your mobile device??
Yes I did. Just says “something went wrong” please check privacy settings and ensure local network is turned on. Which it is turned on. Turned on and off restarted my phone as well.
Honestly can't say what's happening with your device
I use an iPhone, so needed to disable automatic time zone to change the date.
After that when I tried to connect it went through the cycle of messages on my television screen and I was able to reinstall. Chromecast
No me deja conectar mi Chromecast
