GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
I came back to tell you that I did the factory reset and was waiting for the update which until today didn't come so I thought 🤔 hmm... let's rol back the time on the phone, disable auto time updates in settings > system > time. Set it sometime before March 2025. After that I was able to set up new device with the latest update.
Enjoy the streaming once again but the fact that big tech basically have a kill switch embeded in their devices we bought and own, gives me considerations about my future purchases from any big tech not just Google
I can confirm this works
Hi Team, can we know an update on the fix steps for the reset devices?
Repost from @johnnyzero2
For all the people who performed a factory reset during their initial troubleshooting, this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started rolling out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 7, 2025 or earlier. If you don't know how to do that, see below.*
2) Use the Google Home app to re-setup your Chromecast by adding it as a new device (+). You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Most importantly, it'll now be reconnected to your Wi-Fi network so that it can receive the firmware update fix.
3) Change your phone's date/time setting back to Auto now.
4) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Note: Supposedly it's being done as a "phased rollout", so it could take a while for the firmware update to hit your Chromecast. Also, some have reported that power-cycling your Chromecast (unplug/re-plug the power cable) will sort of "provoke" the firmware update to be installed. Patience.
*How to change your phone's date/time settings:
For iPhone/iPad: go to Settings, General, Date & Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
For most Android phones/tablets: Settings, General Management, Date and Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
**Google REALLY should pin this information to the top of this page.**
I did a factory reset the 1st day...
Any further update in this?
Google should pay us for figuring out the solution for factory reset devices.
The community solved the factory reset issue before google give the solution to this matter.
There are numerous responses how to but google still doesn't want to pin any of them or just rewrite a solition.
Hi, the fix for reset is on this link. It works!!!
@rgold @Pradeep3125
How is progress?  I reset my device unfortunately.
 Still not wirking on My chromecast vidéo and audio gen2 😞
既にリセットしました。
anda logo
All my paid app subscriptions are going to waste. Google, you are literally causing me financial loss. You guys need to fix this asap
**bleep**, I already did a factory reset. I hope y'all can fix it. This is the only trouble I've ever had with my ChromeCast
GlennFeit
I have three Chromecast Audio device. I factory reset two before I saw the warning here.
On Friday, the fix came through for the one Chromecast Audio device that was not factory reset.
Today, I was able to fix the two remaining Chromecast Audio devices!
By manually adjusting the date on my phone to the day before the Chromecast's security certificate expiration date (March 9, 2025, the root cause of the problem) I was able to set them up, allowing the firmware fix from Google to install.
All of the (3) Chromecast Audio devices are now operating beautifully!
Still having no luck with the chrome cast g2.
this is starting to feel like a  bug that will require a new purchase …  iPhone like.
not happy
I did a reboot not factory reset and home finds chromecast but won't set up ..gets communication error
You said that the fix should be release over the next few days => few days for you it’s 4 (currently), 5, 10 … 30 days ???
Anonymous
Not applicable
To work, you need to set your date on the phone to a date before 9 mars, then You can set up the chromecast and it will download the new update. It worked for me.
The tip to reset the phone clock to March-5 worked just now, ~8gmt 2am PDT seattle.  Be sure to reset the time back to automatic after the update finishes, otherwise the audio wouldn't cast.  Happy now.
How come my Chromecast is totally dead now? Like no light anymore. Is this a common thing with this worldwide issue?
The chrome cast device is not connecting with the TV. Casting is not working and showing as outdated version.
Anonymous
Not applicable
You can set your date on the phone to a date before 9 mars, then You can set up the chromecast and it will download the new update. It worked for me.
My 4 devices still are not working.. please update
Hello
I reset Chromecast and now I can't install again. I waiting for help with this issue.
Thank you
Anonymous
Not applicable
I factory reset it trying to sort it last week. Help
Anonymous
Not applicable
For those who did a factory reset on your chromecast, set your date on the phone to a date before 9 mars, then You can set up the chromecast and it will download the new update. It worked for me.
Thank you so much, it worked!
Rested devices Solutions. Please 🙏 🙏 🙏 🙏 🙏
C est long et pénible quand pensez vous résoudre ce problème 🤬🤬🤬
For those who have reboot your chromast, set ur date on the phone to a date before 9 mars, then You can set up the chromecast and it will download the new update. It worked for me
Anonymous
Not applicable
Thanks man. You are gold! Worked for me too!
Anonymous
Not applicable
Thank you very much!! It worked!! 🥳🥳🥳
Come on Google why fix something that isn't broken
Anonymous
Not applicable
And for us, those who did a factory reset? Any solutions yet?
I did the reset. What should i do now mates?
My chromecast problem was not solve
