GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
Wow this really worked, thank you anon!!
Merci !! J'avais malheureusement réinitialiser.
J'ai changé la date sur mon téléphone pour le 07/03/25 et après avoir ouvert l'application HOME j'ai pu me connecter et installer la mise à jour. Il fonctionne de nouveau.
Anonymous
Not applicable
manually set the date on your phone prior to march 9th, something like march 7th
Then open google home and set the device up, it will connect as a new device. Once it's on your wifi network, sit back and wait for the pushed update fix, feel free to set date back to current on the phone once the chrome cast device is back on wifi
Gracias,  lo hice y pude conectarlo a la red wifi. Ahora esperaré la actualización de Google. Gracias!
Grazi
Eu fiz isso, mas voltei com a data correta no meu celular, dá problema em voltar com a data certa ou tenho q ficar com a data atrasada?
Depending upon your Phone OS, stop automatic update of date and time, manually set data and time of 7th March 2025 or anything earlier than 9th March. Now force close the Google Home app and re launch it. You should be able to setup your Chromecast. However, it will still not allow to cast due to untrusted device error which has to be fixed by Google team.
Thanks for your input! In my case I factory reseted my chromecast gen2 and was unable to connect to app Home. Now I succeeded and waiting for google solution. Screensaver again on TV but unable to cast.
Anonymous
Not applicable
I have already reset the device. I have a Chromcast audio and the problem still exists.
Yes, they know that the problem still exists, especially for users who have reset their device. Did you actually read the post?
**bleep** you! He has every right to complain! What are you? Google's lawyer?
Everyone's read the **bleep** post and everyone's still pissed off!
MarisolAja
Mandarme las instrucciones a #. Lo hemos restablecido de fábrica.
R7x
Bullsh*t bye Chrome**bleep**, hello Xiaomi
CarlosSouza
Boa tarde.
Restaurei achando que voltaria e ficaria grato se retornar a msn, informando que foi resolvido o problema, pois uso bastante os meu 2 aparelhos, pq não é fácil ter 2 crianças entendíadas dentro de casa.
Aguardo retorno.
Att.
Carlos
Spbrend
Ya hice el reset que procede? Fue antes de recibir este correo
legend-80
I like that FEELING OF JUST GOT PAID YEAH FU
Ferks123
When is a fix coming?
Fabiomoreira
Eu restaurei as configurações de fábrica, preciso de informações do que devo fazer pois n consigo mais ativar o wi-fi e configurar ele
Pablo8
Sigue sin funcionar! Mintieron! Tengo el Chromecast 2a. Gen. y no toque nada, no restablecí de fábrica ni nada de eso. Nos cagaron! Habrá que comprar uno nuevo más actual, para beneficio de google.
wormhole23
Nicht zurück setzen. Das erzählt ihr einem fast eine Woche nach dem Fehler. Typisch
armand_catalan
too laten, I have already bought a xiaomi tv set
I hope you will repair the chromecast as I can try to sell it
mrraffu
Already did..
Anonymous
Not applicable
What are we doing if we already factory reset it ? There is no way to update it since it's not link to my account anymore?
Anonymous
Not applicable
EVB
Ik had mijn chromecast ook teruggezet op fabrieksinstellingen en las dat iemand op deze community had geadviseerd: 1) om de datum op je telefoon op 8 maart te zetten; 2) op de Home app te gaan naar "Apparaat toevoegen" en 3) de instructies daarop te volgen. Dat heb ik gedaan en ja hoor, mijn chromecast werkt weer.
Ahill17502
Lol "do not factory reset your device" Too bad that that was literally #9 on their check list when I googled the issue Monday evening. I literally followed the instructions to troubleshoot the issue & now my chromecast is bricked. Weird that I didnt receive an email telling me there was an issue until right now (Thurs @ noon). I already threw my chromecast out thinking it's done.
Zuleisly456
Does this apply to 3rd Gen Chromecast? I have been days unable to connect, authenticate or communicate with my Chromecast. I have factory reset and still no luck, please fix.
Yes 2nd and 3rd gen
Yazmin
No sé puede conectar
Cykeron
Good afternoon. Thanks for the information. Approximately how long will it take to reach everyone affected? I haven't been able to use it for four days. I just checked, and the problem persists. Best regards.
Batuel
Infelizmente no primeiro dia eu fiz o.reset no meu aparelho.
Dante515
This issue began Sunday March 9th. After spending 2-3 hours trying to correct which INCLUDED multiple x's Factory Resetting, you folks then "show up days later" and state DO NOT FACTORY RESET.
You "tech nerds" are DEVOID of context and sensitivities. Your COMPANY is OPAQUE in it's endeavors. How about FIXING this "Google GENERATED GLOBAL error" and communicate and compensate those of us who've been negatively effected?!
LisiMN
No dia que deu erro, eu resetei ele, e agora? quando a atualização estiver liberada ele vai voltar a funcionar?
Damaris
Ya lo restablecí . Ojalá den una solución pronto ya que todas mis teles usan chrome cast
Ali_baharun
Saya sudah berkali me-restart Chromecast gen 2 saya
Ollek
I did a factory reset of my chromecast 2nd generation. I need help too get it fixed. Can’t connect to WiFi when I trying to perform the new setup.
ponga en la tablet fecha del 8 de marzo de 2025, lo podrá conectar pero no usar hasta que solucionen el problema de ssl
Vishnu1981
Try changing the date on your phone manually to March 8, 2025 (prior to the date of the problem) and from the Home app add device, when it asks you for the wifi password try to enter it manually and to all the other questions answer "not for now", and thus I managed to get the Chromecast to connect to the Internet, the clock will now show the updated time therefore it has a connection, now you can stream videos if you can't until the corrective patch from Google arrives, but at least it is now online to receive it.
Adminuser01
Patience have a cost, tell me we gonna have compensation for this.
Im all google with every tv at home and nothing work right now, very frustrating.
Melomaniac
Hi !
I have total 7 chromecast units bricked around my house. Chromecast Audio 4 and 2nd gen chromecast TV 3 devices. To replace these with something else with UPNP or Apple Air link devices (not releted anymore to google and chromecast technology) is going to cost me some money but this is not end of the world.
It is lesson learned ! Ther is so many cheap devices to buy (stay away from word chromecast)
Any old tv box even with older android version with audio out can be used as audio streamer ( Minix, Gbox etc)
Raspberry Pi 4 (silent, no fan) as audio streamer, cheapest 2 GB version is more than enough.
For TV streaming there is so many cheap devices and you know their names.They working same way or better than your old overrated chromecast.
For number of years I was reccomending Google devices as best working to all my family and friends.
Imagine how do I feel now after this big stink that Google created.
We simply lost Trust in Google !
END OF STORY
GOODBAY GOOGLE DEVICES
I am cancelling my Google services which I am paying subscription monthly and I am reccomending to you to do samething in order to say Thank You ! Google for your hard work !
Please do not lecture me not to panick and wait for fix.
Too long wait for all sick and older people that can not move out of the bed and they were cut off from listening to the radio stations and watching TV !
Shame on you google !
Cilegro
Aguardando o retorno ou reembolso para adquirir um novo dispositivo. É um absurdo ter que aguardar mais de 4 dias para uma solução.
