GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
PriscillaMaris
 If have already factory reset my device,
Puissance
Thanks for supporting Chromecast Audio still!
diaavila
Necesitamos más compromiso de su parte, pues sobre todo esta generación la adquirimos para no tener problemas de sincronizacion como con Alexa. Compre dos Chrome cast y ninguno funciona, es aquí cuando pierdo fe y mejor compro un Roku q no tenga problemas como estos 🙄
Lilyebugao
E quem já restaurou o aparelho e agora não consegue fazer a configuração o que faz?
Shicky1
This ain’t right, I haven’t been able to watch my shows for days now! We should be get some kind of compensation for this, a brand new chromecast and free google stocks.
Deboramdq
Quisiera saber si tengo que mantener el dispositivo encendido para recibir la actualización y si hay fecha de solución
Anonymous
Not applicable
So when will the problem be solved?
Vallombardi
Inadmissível uma ocorrência dessas e o tempo para solucionar. "Google", quem?
Gigi2
How can i fix the problem
Javier51
Please fix this issue ASAP, is very necessary for mi store
On what date is this problem resolved?
Octember 35th.
Your date is very cool
congratulation
johnnyzero2
I can confirm that the workarounds posted on Reddit and elsewhere will indeed restore Gen2 casting from Android devices and Chrome browser (sorry, iPhone users). I had mine back up 'n running by Monday morning. Not perfect, but for those who are impatient (and reasonably tech-savvy), it's a viable option until Google issues a proper security certificate fix.
https://www.reddit.com/r/Chromecast/comments/1j7lhrs/comment/mgy1a88/
https://mensfeld.pl/2025/03/bringing-your-chromecast-back/#how-to-fix-it
SimonDune
This has been here since Monday but you wait until today to email us? Of course many will have done a factory reset by now. This was unbelievably irresponsible.
Anonymous
Not applicable
Set your phone to March 7th and reinstall device with the Google Home app.  It will then be online and will receive the updated certificate.
Annika028
Chromecast not working. Can't connect to internet.
jimmyD123
PLEASE FIX NOWWW!!!!!!!
Aldoluduena
Tengo la solución lo probé y anda perfectooo
Les dejo el link donde lo probé y ahora estoy usando mi cromecast
https://youtu.be/2yu3wQ58cm4?si=lk_ffuSPva2mfFNV
Rodrigo203
Por favor, corrija
Pablo87
Cuánto tendremos soluciones?
Laszlo1
thanks for the information. Unfortunately the first thing was I have done as the error popped up after switching off and on the factory reset of one Chromecast device of three :-(. I hope is not a big problem...
AhoraMismo
Yes I did a factory reset 'cause I had no idea what was going on and now I can't reset it up anymore. 😑 How am I gonna know when you guys have fixed this mess? Oh well I guess I'll have to try every day. What a waste of time.
Or, you can just periodically check this page. The current status and any updated information will always be pinned at the top.
DavidCosta
I'm wait to solution to my chromecast. but I reseset my device. when solution to publish I see how make.
Anonymous
Not applicable
Set the date on your phone to March 7th.  In the Google home app, reinstall the impacted Chromecast.
Thx i will try that.
Should it work when the roll out the update?
Anonymous
Not applicable
I just got an update on my chromecast!!!  Yay!!   It looks good!
Charm51
Tell me what to do
andycn76
Is this day 4 or 5 now, and you still haven't fixed it?? How can a company like Google f*** up what should be a simple fix for so long? Utterly ridiculous.
Jean-Jean
To late factory reset done  …. Hurry up
JorgeWill
E o período sem uso, vamos ser ressarcidos como?
manugeneston
Bonsoir quand va-t-on pouvoir récupérer le fonctionnement de notre chromecast car cela est franchement pénible d'acheter du matériel et que au bout de quelques temps il soit obsolète dû à des mises à jour ou des choses que Google ne fait pas dans les temps. En attendant c'est les gens qui ont acheté ces appareils qui sont pénalisés cela n'est absolument pas normal au vu de la grandeur de la société Google....
Knighty1
Well when are you guys going to fix this ,,???? It's been awhile now is anything been done ????
Aldoluduena
Acá les paso la posibilidad de poder ver en su cromecast ya lo probé y anda perfecto
Les paso el link de YouTube
Clauber
O meu pediu para reconfigurar  de fábrica é não entra mais tem 4 dias... aguardo retorno.
pattyramss
Mi Chromecast dice que no auténtica 🧐
