GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,145 REPLIES 16,145
Frailley
Stef69
Exactement le même problème depuis hier soir...
Marymartins
Altere a data para o dia 07 de março
e refaça a configuração do aparelho
vai voltar ao normal !
refaca
Feche o house e todos os aplicativos após a alteração da data e tente novamente
Da para configurar o chromecast novamente mas a imagem não passa.
Pjuskebamse
Hi from Denmark
my Chrome cast doesn’t work not active. Why
I have the same issue, Netherlands here. Worked fine for years. Until yesterday.
Česká republika, stejný podobném, včera přestal fungovat. Zná někdo řešení?
Oprava textu-stejný problém
Look a the pinned message. Its a bug. All older Chromecasts are down, due to an expired certificate. Google is working to fix this.
Paulobranquin7
Eu restaurei para as configurações de fábrica. O que eu faço agora ?
LMMC1989
Very poor effort from Google. Must do better
Cathy3
No sé pudo autentificar.
Hice todos los pasos y nada.
Me pasó con los dos aparatos que tengo.
Here's a notification from Google Nest Team... in a few words... we have to wait 💀 https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
DMV
Me pasó lo mismo. Ayer se desconectó y no logré reconectarlo. Lo restauré de fábrica, desintalé la app y nada...alguien sabe que más hacer? El firmware del router no es, también lo chequeé. Gracias!
Sofia86
What is wrong with chromecast??
I tried everything possible,delete/set up/reboot EVERYTHING,nothing worked..
I assume is an international issue ,what about any official announcement from Google..? I don't want to believe that they try to push out the gen 2 device and they do what they do "unofficial" but this is really disturbing!!!!
Dipesh94
I am also facing same issue with Chromecast. Sad to hear this.
Stesso problema da ieri contemporaneamente su Tutti i miei 3 Chromecast audio
SabbyNy
I'm having the same issue I'm in NY, usa
It's a known worldwide issue.  @madebygoogle is replying to tweets about it along the lines of "We're aware of an emerging issue impacting Chromecast 2nd gen and Chromecast Audio devices and are working on a fix."  I have yet to see an official statement about it, though.
Troels79
Facing the same problem here in Sweden. Speed 2 hours Yesterday troubleshooting both mu Chromecast Audios
Sofia86
Right, no official announcement, just replies to tweets ..It seems to me like they want to figure out how "big"the impact will be before making any statements..
Cynlee
Same, since yesterday.  Unable to cast from my ipad.  So what do we do in the meantime? Go buy an updated version?
Lubash55
I have had this problem since yesterday.  Any action to solve it has been useless.
I'm reading different blogs in which people say that it is probably a bug in the system.
But there is no official notice from Google and it is incredible.
My problem in Italy
AaBe
Same problem here in the Netherlands. Started yesterday 9th march. I have 3 audio Chromecasts and one tv. All "off line"
AGA3
 Chromecast 2
W Polsce to samo.
I am from India and facing same problem since morning more than 20 hrs now. Yet no solution from google.
oitaus78
Same here 2 chromecast dead. No Netflix, no Skyshowtime, no MAX, no youtube on TVs. Romania
PLB1
Latest update (on reddit) is that a security certifcate governing Chromecast 2 access to internet has expired (Google gave it only 10 yrs validity and forgot to renew) and they are now working on a fix. No indication how long it will take, however....
AaBe
Thanks for your reply.👍
So we have to wait..... And not factory reset the devices, as I read elsewhere.
rwn1
Same here. Thought its the chrome cast itself. Tried everything too. So lost without it as we are using to cast Netflix on the tv
Gisselle
Same problem from Uruguay
Here's a notification from Google Nest Team... in a few word... we have to wait ☠️ Regarding an issue with Chromecast 2nd gen and Chr... - Google Nest Community
Bas3
Hier de workaround/fix om je chromecast v2 weer te laten werken, voor de Nederlanders onder ons, die Android gebruiken:
https://www.googlenestcommunity.com/t5/Streaming/Hoe-je-de-ChromeCast-2e-Editie-weer-werkend-krijgt/...
peterbang
 I wasted a whole Sunday afternoon trying to figure out the problem. As per their troubleshooting guide I ended up factory resetting it. Now today told not to. I am so 😠  frustrated.
Same here .  I was watching Netflix with my daughter and once the movie ended ( I was just lucky here ) I was no longer able to cast anything like music from YouTube … i have a second one that wasn’t working either so I rebooted the WiFi router , then factory reset , etc 😕
Abask
Please let us know at least an estimated time when you will resolve this
Ailin22
Desde el día de ayer no puedo usar el Chromecast por que dice que ya no es confiable. Que puede que el firmware esté desactualizado y nose como solucionarlo.
Since today morning I am not able to use Chromecast on my TV as it’s says Firmware is expired. Dear Google support team please provide the resolution.
