GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,146 REPLIES 16,146
Read the status update pinned at the top of this page. Google started rolling out a firmware update fix yesterday.
If you've done a factory reset, you'll need to do this procedure in order to receive the update:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Phil000
factory reset my device (Chromecast)  ,I  cannot re-setup my device , When are you going to resolve this.
Nmr1979
Set your phone's date manually before march 9th and re install your chromecast.
Anonymous
Not applicable
Just set your date on your phone to something like March 7, 2025 you'll have to do it manually then use Google home to set up the device again it will connect to your Wi-Fi once it's connected to your Wi-Fi go ahead and unplug your Chromecast device and plug it back in it'll reboot and it should update.
Don't forget to set your phone back to current date.
this worked for me!
Chromecast gen2, setup using iPhone 11
AdeC
Hola! Hay previsión de cuando estará solventado?
Gabriel600r
JackHoff
Please send everyone on this thread a new Chromecast. Your response and action thus far is unacceptable and EMBARRASSINGLY pathetic.     👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻👎🏻
Mmkd1987
Any estimated time frame for the fix for those of us who factory reset ours?
I can't believe that Google hasn't pinned this information to the top of this page, for all the thousands of folks who have done a factory reset.
In any case, it's a fairly easy fix. Just do this:
FransinaRB
Hola, estoy intentando vincular mi cuenta a través del teléfono móvil con la App de google Home y, aunque verifica el número del chromecast (7163) cuando tengo que escribir el código de verificación, la aplicación se queda colgada y muestra un error, sin dejarme insertarlo (el número que aparece en pantalla).
Cómo puedo solucionarlo?
Mi correo electrónico es: #
Ya he eliminado mi cuenta en el google Home y he desconectado varias veces el dispisitivo más de 10 minutos y también he eliminado la aplicaxion y la he vuelto a instalar, también he reseteado el wifi
WRX222
I hope Google realizes that just about everyone of us did a factory reset before knowing we shouldn't be doing exactly what is, well was, advised to do in an event like which has occurred. Just for the record I'm still with no chromecast and I yes I am one of the many who did the factory reset before knowing any better. I hope they fix it.
I can't believe that Google still hasn't pinned this information to the top of this page, for all the thousands of folks like yourself who have done a factory reset.
In any case, it's an easy fix. Just do this:
WRX222
Hello everyone you need to listen about setting the date back on your phone or tablet if you did the factory reset. It works. You get the update instantly and you can change the settings back on whatever device you did the initial install with. It works people. Thank you to all the megaminds who have the thought process to narrow that problem down to what you did and for providing us with the solution. Literally saved my entertainment life. Sincere spank you helpy helpertons!
Huepaz
What do yo do if you have an iPhone?
sandrapierling
Chromecasts
Ein Teil der Chromecast-Besitzer ist derzeit laut Google nicht in der Lage, das Gerät wieder in Betrieb zu nehmen. Ein Trick könnte helfen
Datum auf dem Smartphone auf vor dem 9.3 2025 setzen dann funktioniert es auch wieder  einwandfrei mit der chromecast Einrichtung und dem streaming
Lucaron97
Y si ya lo puse como salido de fábrica? Cómo lo reinicio?
Janselmus
Realmente voltou a funcionar.
Fer81
Si se hizo el reseteo de fabrica se puede cambiar la fecha del celular al 7 de marzo y de esa manera se conecta al wifi sin inconveniente. De ahí en más se hace la actualización sin inconvenientes. Luego devolver a la fecha actual antes de probar de entrar a Netflix, por ejemplo, si no tira error. Suerte!
m1nbille
Well done for fixing! Thanks for the big effort 😄
WRX222
Man you all figure everything out. Thank you so much! It worked! And it's updating!
Barbara84
Ya me funciona. Gracias Google. Sin embargo es una verguenza lo.que ocurrió. Me di cuenta que se soluciono cuando encenfinla tv y me aparecio una actualizacion. CERO TIENEN UDS EN COMUNICACION AL USUARIO CLIENTE!!! No hay comunicacion por ningun medio. El tiempo que mucha gente perdio. Mucha gente reiniciando a fabrica xq uds es lo que revomiendan.. ni hablar de aquellos que modificaron horarios. La verdad me sumaria a la demanda internacional que lei que van hacerle. La pregunta es como van a recompensar a sus clientes????
People make mistakes, companies make mistakes. Also, we're talking about a 10-year-old sub-$30 TV dongle. I think it's actually pretty remarkable that Google still supports it at all, given that it was released 10 years ago. That's pretty unheard of in the tech world.
Akash0709
Pls fix this asap .. It's annoying
If you've already done a factory reset, you'll need to do this procedure in order to receive the update:
AhmedOmar_1
Hi There, I am facing an issue with my chromecast 2nd generation not connecting to my TV and it displays authentication problem.
Appreciate your prompt support
Regards
Me too; since the 9th of March....
Do not restore factory settings, just keep the device connected to your Wi-Fi network and wait for the update to download.
I moved my date back to 8th March still not picking WiFi
Moi aussi depuis le 9 mars...
Elias_91
En algún lugar ya han solucionado? Funciona el cambiar de fecha para configurarlo? Estoy conectado pero no sé si me tomará la actualización, alguien tiene novedades?
Si funciona ya se me ha actualizado
En mi caso también, se actualizo y se resolvió. Me queda revisar que paso con uno que reinicie de fabrica.
Yo tengo 2 y el que no resetee ya me funciona. Espero que nos den tb solución para los que reseteamos de fábrica.
Tengo 2, uno no lo había reseteado, y ese empezó a funcionar hace un momento ya.
MFMCL
Desde anoche mi Chromecast audio funciona ok.
Pero nunca lo llevé a modo fábrica.
Chromecast81
Hi there is the chromecast still not working?
