GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
Sí anda , graciass equipoooo google!!!!
Personalmente da me Torino Italia è stato sufficiente riavviare il Chromecast ed è giunto l'aggiornamento,che prima automaticamente si e scaricato ed a seguire sè installato! Ed ora funziona come prima tramite Google Home Grazie
Thank you for the support. We have 2 devices home and 1 of then I done the factory reset. I waiting the instructions. The another is working well again.
Ya lo logre, lo reestableci de fabrica, pero desinstale la app de home y puse en mi teléfono Android una fecha antes del 9 de marzo, volví a instalar la app y lo intente conectar con el Chromecast y funcionó por fin se pudo, luego puse la fecha a la de ahora y ya se puede transmitir 🥰🥰💕 (recuerden darle los permisos necesarios a la app)
Se você , assim como eu, restaurou antes da atualização eu consegui resolver. Altere a data do seu celular para 01/03/25 efetue a configuração normalmente, assim que a rede for restaurada no Chromecast ele atualizará automaticamente. GOOGLE PODE MANDAR MEU PAGAMENTO!
Anonymous
Not applicable
If you performed a factory reset, you can still re-attach it to your "home". This will allow you to receive the new firmware with the updated CA certificate installed. Here's how: Using your device (e.g.: Android phone or whatever you have the Home App on), change the date to March 1st. Then add the new device to your home per normal. It will find it as a new device and it will connect to the network and internet again. Then it will get the new firmware when it rolls out. You're welcome 🙂
How long until you give us a fix for those of us who followed Google directions to factory reset? I have to useless  Chromecasts atm.
Ooops I performed a factory reset already (a thousand times, btw)... How will you contact me? When? I'm waiting 🙂
Jootje69
* zet de datum op het apparaat waarop je Google-Home-app teruggaat naar 1 maart
*ga vervolgens naar de Google-Home-app
* zoek en verbind je chromecast
* zet datum van je apparaat terug naar huidige datum
Não estou conseguindo conctar na tv
I've reset my Chromecast, which is the standard solution when it doesn't work. Please fix it soon
Verdade é o que também espero
Lizzyd121
The work around is to reset your phones' date to earlier than 8 March 2025. Run Google Home and add your device. You should follow all prompts. If you are in an area that Google has rolled out the update, you should see an update progress bar on your TV and the Chromecast will probably power reset twice. Don't forget to reset your phones' date. Open Google Home, see if your device is listed.  Open you Streaming App on your phone and test casting. Goodluck.
Jootje69
I already reseted the device before I knew that was a general problem. It's going be any issues because I reset it?
Thankyou Lizzy this worked I love you 😍
Não consegui voltar ainda, por favor me Ajude pelo Amor de Deus🙏
Não consigo configurar o Chrome
I have done everything that has been said to do and still nothing. What else can I do?
Thank you google . It working now
perché ringrazi Google è Google che deve ringraziare noi
My chromecast stop working  I did a factory reset and now it keeps saying can't authenticate the chromecast.  so I can't even add the chromecast back in my Google home app. HELP PLEASE
Hello Team, Thank you for the fix. I had performed a factory reset, however, setting the date manually on all the devices I tried connecting to the chromecast from worked. Also, I didn’t turn off the device or the Wi-Fi for the whole day yesterday. Thank you for all the efforts taken on resolution.
For those of us who set the factory date, the solution is to set the date to March 8, 2025 on the phone, go to home(google) and configure the Chromecast v2 for about 10 minutes. When the configuration is finished, the update is installed automatically. I configured the time zone of my country (Bogota, Colombia) at home(google) and then restarted the device by disconnecting it from the power and reconnecting it and the firmware was installed automatically.
para los que establecimos de fábrica la solución es colocar la fecha al 8 de marzo del 2025 en el teléfono entrar a home y configurar el Chromecast v2 a 10 minutos más o menos cuando se termina de configurar se instala la actualización automáticamente, yo configure en home la zona horaria de mi pais (bogota colombia) y luego reinicie el dispositivo desconectando de la energía y volviendo a conectar y se instalo el firmware automáticamente
After trying to set my CC back up mine keeps saying couldn't authenticate your CC device?
Gracias agradecería una pronta solución a este mail # muchas gracias
This morning, 15th March 2025, around 08:45hrs local time, I got the update here in Srilanka and my Chromecast 2nd Gen is back to normal.
Thank you very much Google. By the way,  I did not factory reset my device.
I not only rebooted my device but clicked forget this device, hoping to re add it to fix the problem. Is there a fox for this?
If you have factory reset your Chromecast, set your phone manually to march 8th and you can set it up like normal. Once it is set up, your device will get the firmware update! Don't forget to change your phone back to the current date afterwards!
I did factory reset and now home is unable to connect to chromecast.  Please help
Anonymous
Not applicable
Another member suggested changing the date on your device.  I changed mine to the 4th March, had also factory reset my device.  I'm now up and running and watching Loki.  Can't find the original message but it worked.
Guys come on! Bricked millions of devices. Hurry up and fix it!!!!!!!
quindi quali sono gli step da fare dopo il factoty reset?
I have one Chromecast which has been affected and one that worked through the week.
But now the one who were affected, works and the other has now problems.
I still can't use my chrome cast. I hope you can fix it soon.
Thanks for the info, however,  is there any timelines by when we can expect the fix where we reset the device to factory settings?
Regards
Anonymous
Not applicable
I had reset the chromecast to factory settings. Google Home could no longer find the chromecast. I set my phone to March 8. Then added the chromecast again with Home. The chromecast automatically updated. After the update everything works properly again : ) Set the phone back to the current date.
Por favor! Hagan algo ya, para los restablecidos de fábrica! Es una locura! Mañana hace una semana ,a mí el mensaje que me pone es error porque dice que mi iPhone no tiene la red local activada y no es así! Está todo ok
