Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-14-2025 12:10 PM
Read the pinned status update at the top of this page. Google started rolling out a firmware update fix yesterday.
03-14-2025 12:10 PM
@Jst5 I also. Been waiting since March 9
03-14-2025 12:04 PM
Me pueden dar instrucciones, porque yo lo reinicie de fabrica sin saber que no era conveniente, y ahora no lo puedo conectar
Gracias
03-14-2025 12:09 PM
@ventosoana I have done the same. They still did not fix the issues.
03-14-2025 12:09 PM
03-14-2025 12:14 PM
Hola, anda a configuración de tu celular cámbiale la fecha pone 8 de marzo como si hoy fuera ese día, luego entra a la app Home y trata de configurar el dispositivo a tu tv luego volve a cambiar la fecha de tu celular a la de hoy y espera a q se actualize, yo hice este proceso anoche y lo deje así ya q lo había configurado Pero no me aceptaba el wifi, lo deje así sin desenchufar ni nada y ahora se actualizo solo hay gente q se le actualiza ahí nomás q hace esto.
03-14-2025 12:07 PM
1 of 2 working now 🙂 it’s even the one I reset (but reconnected to the network by temporarily changing the date on my phone)
yay
03-15-2025 02:14 PM
Hey thanks for the tip i was able to connect the device and update the software
03-14-2025 12:08 PM
As I see that chromecast started to work. Thanks for the problem solving. I hope in future this kind of technical issue will not happend and google supports the cuatomer.
03-14-2025 12:12 PM
I'm back online with chromecast. Thanks Google
03-14-2025 12:12 PM
How many days will it take to get the same fixed ?
03-14-2025 12:15 PM - edited 03-14-2025 12:16 PM
Read the pinned status update at the top of this page. Google started rolling out a firmware update fix yesterday, and your Chromecast should receive it soon.
If you have already done a factory reset, then you'll have to do this fairly simple procedure in order to receive the update:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
03-14-2025 12:15 PM
Thanks for updating
03-14-2025 12:23 PM
03-14-2025 12:24 PM
@becki-63 that is what's on my TV
03-14-2025 12:15 PM
Thanks to Google for this reminder that you should never ever buy a mission-critical system (such as a car) with Google embedded (such as Android auto). Imagine being stuck with a non-functioning system for 5 days...
03-14-2025 12:16 PM
You did it! Thank you so much 🙏
03-14-2025 12:17 PM
Sorry but patience is starting to wear thin. It's been almost a week now. This is kind of ridiculous! This should be top priority for you and fixed several days ago, please get it together
03-14-2025 12:21 PM
@Jessejames1776 yes. That's how I feel
03-14-2025 12:23 PM - edited 03-14-2025 12:25 PM
If you have done a factory reset, then you'll have to do this simple procedure in order to receive the update:
03-14-2025 12:19 PM
So if we have reset the device what do we do? I think you need to offer some kind of replacement solution. Just wait and see is an average at best option. Who do I send the invoice for a new casting device to?
03-14-2025 12:22 PM
If you have done a factory reset, then you'll have to do this fairly simple procedure in order to receive the update:
03-14-2025 12:19 PM
I have NestMini6526 that I cannot connect to, even with my pixel phone
03-14-2025 01:04 PM
I turned wifi on and off and it has connected to my device but isn't connecting to the wifi itself.
03-14-2025 12:21 PM
Ho ricevuto l'aggiornamento, adesso riesco a trasmettere film ma, non a trasmettere lo schermo del cellulare.
03-14-2025 12:21 PM
Bom dia, eu fiz reset no meu chromecast mas consegui hoje resolver. É só mudar a data e hora do telemóvel para antes do dias 9 de Março e depois fazer a configuração normal do chromecast.
No fim a configuração tem que repor a data e hora para a atual e depois é só voltar a usar o chromecast normalmente. Boa sorte
03-14-2025 12:22 PM
I already did the factory reset omg I was desperate 😫
03-14-2025 12:24 PM
Not the end of the world. Just do this:
03-14-2025 12:33 PM
Thank you Johnny! You just saved an Argentinian life
03-14-2025 12:38 PM
I had to remove my user on my android and create it again. Then it started an update and now it works again.
03-14-2025 12:23 PM
Quiero recuperar mis datos
03-14-2025 12:24 PM
Please fix the issue for my chromecast as well.
03-14-2025 12:29 PM
Read the update status pinned at the top of this page. Google started rolling out a firmware update fix yesterday.
If you've already done a factory reset, then you'll have to do this simple procedure in order to receive the update:
03-14-2025 12:40 PM
Remove your user on your devise, and create it again. That worked for me.
03-14-2025 12:25 PM
Yo resetee de fabrica de Chrome cast por qué es lo primero que dicen que haga, y ahora como sigo?
03-14-2025 12:27 PM
03-14-2025 12:24 PM
Hi. I made a factory reset on my Chromecast audio that wasn't connecting and now I can't reconnect into the Chromecast. Can you help me please?
03-14-2025 12:36 PM
03-14-2025 12:25 PM
Hi, when will this be fixed?
03-14-2025 12:37 PM
Read the status update pinned at the top of this page. Google started rolling out a firmware update fix yesterday, and many users have already received it.
