Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-14-2025 06:42 PM
Purtroppo ho già ripristinato le impostazioni di fabbrica
03-14-2025 06:56 PM
03-14-2025 06:48 PM
Purtroppo ho ripristinato alle impostazioni di fabbrica. Cosa devo fare?
03-14-2025 06:55 PM
03-14-2025 06:49 PM
Necesito una solución, llevo muchos días sin acceder a la conexión, dice que no se puede autenticar el chromecast. Necesito ayuda. Gracias
03-14-2025 06:48 PM
Nossa como isso pode acontecer, tomara que deir um jeito o canto antes,agradecido.
03-14-2025 06:51 PM
I had already reset my Chromecast. Now it's stuck at the same place. Please help.
03-14-2025 06:54 PM
03-14-2025 06:52 PM
How you guys will contact me? Begore google annoucement I have reset my chromecast to original. What should I do?
My email #. please reply
03-14-2025 07:01 PM
Just do this, and you'll be back up and running:
03-14-2025 06:53 PM
Cuando es lo antes posible?
03-14-2025 06:54 PM
Oh man, I already factory reset my Chromecast and then came here, So do I just leave idle?
03-14-2025 07:00 PM
No. You'll have to do this:
03-15-2025 09:41 AM
Debes cambiar la fecha del móvil anterior al 9/3, activar el Chromecast y luego se actualizara solo y funcionará.
03-13-2025 09:32 AM
Unable to connect with Tv
03-14-2025 06:56 PM
Any news on what to do if you already reset it ?
03-14-2025 06:58 PM
03-14-2025 06:58 PM
تم اعادة ضبط المصنع عند انقطاعها وما نزال بالمملكة العربية السعودية نعاني ولم نستطع البث والاتصال بكروم كاست الى شاشة التلفزيون الرجاء ابلاغنا بالوقت المحدد لانهاء ذلك وتشغيله
03-14-2025 06:59 PM
I hope you fix of our problem since staring last week .
03-14-2025 07:06 PM - edited 03-14-2025 07:07 PM
Read the status updates at the top of this page. Google started rolling out a firmware update fix yesterday.
If you did a factory reset, then you'll need to do this to allow it to receive the firmware update:
03-14-2025 01:03 PM
Chromecast Audio is working again.
Thank you for the fix.👍
03-14-2025 07:03 PM
Still not working and I reset it
03-14-2025 07:05 PM
If you did a factory reset, then you'll need to do this to allow it to receive the firmware update fix:
03-14-2025 12:28 PM
Thanks for fixing chromecast!
03-14-2025 12:31 PM
Ne fonctionne toujours pas chez moi. Que faut-il faire ?
03-14-2025 07:09 PM
03-14-2025 07:04 PM
não funciona
03-14-2025 01:07 PM
Since yesterday, my Chromecast has been working only on my cell phone. But now, it's back on my computer, too! I'm so happy! Thank you, Google, for having fixed the authentication issue. Cool! And thanks again to Cookie for the big help in resolving the problem while we were waiting for the fix! 🙂
03-14-2025 01:33 PM
Lucky you...I'm still waiting for authentication to be recognised .I had annoyingly factory reset it as have many hopefully it will be restored ,sorted soon....
03-14-2025 07:08 PM
03-14-2025 02:43 PM
Yeah mine still doesn’t work either
03-14-2025 07:28 PM
Did you do a factory reset? If so, then you'll need to do this to allow it to receive the firmware update fix:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
03-14-2025 07:08 PM
Unfortunately I have already done a factory reset as advised by the trouble shoot help. So what do we do now to get it connected again? Thanks.
03-14-2025 07:10 PM
03-14-2025 07:10 PM
Me parece una falta de respeto para el usuario que pago por un equipo y que deje de funcionar por un problema de ustedes y pasando tanto tiempo todavía no haya solución cuando tuvo que ser inmediata. Espero que se solucione rápido o mínimo se hagan cargo de su error
03-14-2025 07:15 PM - edited 03-14-2025 07:27 PM
What do you mean "still no solution"? Read the status updates at the top of this page. Google started rolling out a firmware update fix yesterday.
03-14-2025 07:11 PM
Working again. Thanks Google.
03-14-2025 07:11 PM
I had already factory reset my device before I saw the message.
03-14-2025 07:13 PM
Then you will need to do this:
03-14-2025 07:14 PM
There's a fix I learned in here, you can set the date on your phone to March 8 or earlier an the you should be able to reconnect your Chromecast to the Internet and to your home. I did it this morning and like 12 hours later the issue is entirely resolved.
