GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,155 REPLIES 16,155
lhassing
Working again. Thanks Google.
Monique1
I had already factory reset my device before I saw the message.
There's a fix I learned in here, you can set the date on your phone to March 8 or earlier an the you should be able to reconnect your Chromecast to the Internet and to your home. I did it this morning and like 12 hours later the issue is entirely resolved.
Osakatana22
Instructions for re setting up chromecast after already factory reset please?
Same here
aosii2512
Bad News... I alredy factort reset.... what can I do now?
Ulrika
My chromecast connects to the wi-fi as always, but after 5-10 s, it shuts down. This problem started suddenly a couple of hours ago. Is it because of the new issue? I haven't done any factory reset. Just restarted chromecast and router. It doesn't help.
Gigaparms
I didnt know i could nott restore to factory configs and i did it.
Please let me.know what to do
Nest75
I have 2 Chromecast, both not working, I Factory rest one but not the other. Google fixed both of them without me doing anything
KamiNando
Ça ne fonctionne tjrs pas... malheureusement j'ai malencontreusement remis les paramètres d'usine..je n'avais pas lu cette page..
Que dois je faire?
Kaue
Fiz restauração de fabrica no meu Chromecast  após pane
Oque devo fazer agora
If you did a factory reset, then you'll need to do this to allow it to receive the firmware update fix:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Sono riuscito
Grazie mille!
Anonymous
Not applicable
Mine started working again. Thank you.
We definitely need to be compensated somehow.
Sacha2
I wish mine worked I did a factory reset and now I can't even get it to download on my Google home app
Ale-rojo
Tengo dos Chromecasts y no puedo conectar ninguno.
En los avisos dicen no restablecer configuración de fábrica.
Podrian haber avisado antes!!!!
Tamrow
My Chromecast Audio is working again!
MarianaBI
Buenas noches!
Tuve problemas para reproducir desde mi celular a la TV A través de mi Chromecast. Consecuentemente reestablecí el producto de fabrica. Luego ví la noticia de que sugerían no hacerlo. Se que aún están trabajando en una solución, de todas formas me gustaría saber cómo proceder en mi caso, ya que supongo que nomdebonser la única en esta situación.
Desde ya muchas gracias por su tiempo.
Matuky
La solución al problema es cambiar la fecha del dispositivo móvil con el cual estás configurando es decir yo puse 2024 y configure mi chromecast sin problemas y luego se actualiza solo esto funciona para los que restablecieron de fábrica
ViXN
Unfortunatly i had already factory reset my device before knowing that i shouldn't. What can i do now to get my Chromecast back up?
dolly21
Ok you'll do this:
If you have an android phone, you'll go to the top right corner of your phone and tap the settings option, you'll tap on general management, then you'll tap on dare and time, make sure to turn off automatic date and time, then from there change the date once you've done that just go to Google home app and set up your chrome cast 😉
Huguito
Hola a todos hoy probé lo que un usuario dijo y funciona cambien la fecha manual a su teléfono y coloquen una fecha anterior  a7/3/25 y intenten conectar con home el dispositivo se conectan luego se actualiza y listo vuelven a poner su fecha automática y solucionado suerte saludos
dolly21
Yo tambien hice lo mismo y si funciono!!!
Ravi7
Now working  Thanks
Cjveradiaz
Les comparto lo que hice y me funciono, inténtelo puede que les sirva, puse la fecha de mi celular en 7/3, vuelven a instalar y se va a actualizar y solucionado
Como lo pudistes hacer?
Dikard
Meu Chromecast parou de fazer transmissão para a tv e pediu atualização mas agora não consigo nem transmitir nem atualizar
Xochitl1970
Queremos conectar el dron y no nos da este nos dice que no hay conexión se queda ahí nada más como que lee y nos dice que no fue conectado ya se ha recetado se ha reseteado varias veces
Sandro25Santos
Olá,
quem fez reset no cromecast, já tem várias postagens de como resolver a nova conexão, irei reforçar aqui.
  • 1 no seu celular desligue a data e horário automática e volte para o dia 8de março, assim você conseguira fazer a conexão do cromecast na tv, mas ainda não fará transmissão, esse passo é importante pois só assim o Google irá conseguir atualizar a firmware do cast. (Verificar no Google home em configurações e versão)
2 se conseguiu fazer o passo acima aguarde até sua firmware atualizar para a versão 1.56.417165, estando já com essa firmware instalada volte a play story e desinstale e reinstale o Google home e a magia acontece, pra quem ainda está com a versão de firmware anterior aguarde a atualização do dispositivo, mantendo ele conectado a internet e ligado, mas nada disso acontecera se não fazer o passo 1.
Forte abraço.
Yoann13
i need help i have reset my chromecast gen 2 4 days ago and i heard about the problem with chromecasts gen 2 so now i have reset everything and nothing works anymore. Can someone help me out please. If it’s possible in dutch or french ? Thanks a lot
Hello, If you had unfortunately factory reset your Chromecast during this issue, go to your phone Date&Time settings and turn off automatic date set, manually change the date to March 7, 2025. Now try to set up the Chromecast again and it should work again.
