GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,159 REPLIES 16,159
Josyyyyyyyuu
Reiniciei meu Chromecast como faço pra voltar
ZuheMiri
Hola buena noche, ¿tendrán alguna noticia favorable para reestablecer el servicio de dispositivo?
Joelma05
Continua com defeito, quando será solucionado? Aguardo retorno.
amyikin01
After a few days waiting, I can finally cast Youtube programs from my mobile phone to TV.  How nice.
How did you do tgat
I reinstalled the Google Home and  tap the cast icon of the YouTube, and found out  it works.
placeinline
Just to compound my woes with this problem.
While doing my original fault finding before any notification, not only did I factory reset the device but also deleted it from Home. Therefore, I cannot even attempt the current semi-fix as Home can only find the device but "cannot communicate with the device".
Obviously I was being a bit too thorough but I'm a bit stuffed now! Hopefully their fix will cover this as well.
  • Go to your android settings
  • Search day and time or scroll to find it
  • Take automatic date and time off
  • Choose day before u did reset cast device i Choese 05.03.2025
  • Open google home and connect device get update for cast. Done
  • Remember to change your date to automatic after your cast is set.
Same here.. I deleted the device! Waiting for a reply
Ritesh1
I too got an firmware update & now it is casting. thanks google support team for your efforts on resolving this on high priority
iona
Já redefinir então quero prazos estou sem tv
GedeWid
Hi Team,
Do you have guidance if the Chromecast already Factory Reset ?
Thank you
Lumikahu
FOLLOW THESE STEPS (FACTORY RESET CROMECAST) FIX
Worked for me! Thanks!
NiallOD
Yep, this is the solution
Nish72
It has been a while now since my chrome cast hasn’t been working. How long more do I have to wait coz I watch heaps of series on Netflix during my days off
Lumikahu
archbishop
Bit late advising people not to do a factory reset when that’s the first thing they normally ask if you have done when phoning a help desk… now smart tvs are having a problem and they suggest to try doing a factory reset???
Lumikahu
Wilsonsaenz
Lastimosamente yo lo restableci de fabrica y ahora ya no puedo entrar por favor espero lo resuelvan lo más pronto posible gracias
ejmata305
How old is this Google message??
In top of that, the speakers start screaming on its own telling me to report it to Google. But Google is nowhere to be seen… or contacted. Unbelievable!
Google Display?… useless!
Why did I buy these speakers ?? They are controlled by Google, and Google is missing in action!
Anonymous
Not applicable
Eu reiniciei e não consegui conectar mas peguei uma dica aqui e funcionou. Mudem para o dia 08 de março o celular manualmente e conectem que dá certo! Atualizou e voltei o celular na data de hoje. Está funcionando, obrigada as dicas aqui dadas pelas pessoas comentando.
webx21
Yo ya compré un fire tv stick pensando que mi chromecast estaba dañado
Lumikahu
Open google home and connect device get update for cast. Done Remember to change your date to automatic after your cast is set.
placeinline
Tried the following "
  1. Under "Technical information," check for Cast firmware version: "X.XXX.XXXXX." If it's a display, check for Fuchsia Version: "X.XXXXXXXX.X.XXXXXXX."
Not for CCA2 ? Nothing appears in the app at this point.
Nachomona
If you factory reset your Chromecast (2nd Gen or Chromecast Audio) and now you can’t set it up because it shows the message “Connection problem”, here’s a solution that worked for me:
Steps to fix the issue
1️⃣ Change your phone’s date to March 6, 2025 (or a day before the issue started).
2️⃣ Open the Google Home app and try setting up your Chromecast as a new device.
3️⃣ Once the Chromecast connects, it will automatically download Google’s update.
4️⃣ After the update is complete, set your phone’s date back to the current day.
🔹 That’s it! Your Chromecast should now work correctly.
💡 Note: This solution may work because changing the date prevents the device from detecting the expired certificate, allowing it to connect to Google’s servers and update.
omg i cant belive it worked thank you so much you're a hero bro
mindzh
bro this was amazing, thanks my guy, out here saving lives
Rachhh
Thank you soooooo much!!! You are a genius. This has fixed the problem for me. Thank you!!!! 🙏
This worked for me.  Thank you so much.
Lucy9
Omg you are my hero
Lucy9
It works
Hiram1
Ojalá Google te contraté para su departamento de atención al cliente.... Funciono!!!!
Awesome! Worked straight away.
S71n4
This worked!!! You're a hero @Nachomona
Jhessy
Aqui deu super certo
Valeu
