Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
03-20-2025 10:49 AM
03-15-2025 07:39 AM - edited 03-15-2025 07:39 AM
03-15-2025 07:36 AM
Sábado 15 de marzo y aún no está restablecido!!
03-15-2025 07:39 AM
Does this affect Google Home Mini Gen1 and Nest Mini Gen2? All my Google Home devices are not accepting any kind of cast...They still respond to commands, but I'm unable to cast Spotify and Youtube.. 😞
03-15-2025 07:41 AM
Infelizmente eu resetei o aparelho, e agora?
03-15-2025 07:44 AM
03-15-2025 07:39 AM
O problema continua dia 15 de março, até qdo?
03-15-2025 08:05 AM
C'è ne faremo una ragione? Oggi è 15 e ancora adesso non riesco a configurare la mia chromecast che sino a lunedì 10 andava cge era una meraviglia. Aiutatemi,siate semplici nelle spiegazioni anche perché ho una certa età ☹️
03-15-2025 07:44 AM
You’re not intending to solve the problems with chromecast, are you?
03-15-2025 07:50 AM - edited 03-15-2025 07:51 AM
Read the pinned status updates at the top of this page. Google started rolling out a firmware update fix on Thursday.
If you performed a factory reset, then you'll need to do this to allow your Chromecast to receive the update:
03-15-2025 07:35 AM
I already did a factory reset what can I do now please?
03-15-2025 07:47 AM
03-15-2025 07:45 AM
Okey
03-15-2025 07:48 AM
第一世代も使えるようにしてください。
今まで使っていたものが急に使えなくなる状態になるのは困ります。
リリースしたのであれば使用している人がいる限り、最低限利用できる状態でサポートするべきではないですか?
03-15-2025 07:55 AM - edited 03-15-2025 08:00 AM
You're an anti-Semitic idiot troll, but I'll give you the solution anyway. Just do this:
03-15-2025 07:49 AM
Hi
I did the reset the same day the problem comes out. We didn’t know it. Whatsapp can we do now?
03-15-2025 07:52 AM
03-15-2025 07:52 AM
Pessimo, não tivemos nenhum tipo de informação ou notificação sobre oque estava ocorrendo, em uma tentativa desesperada de tentar voltar o dispositivo, fomos instruídos por vcs a reiniciar a configuração de fábrica e agora estamos, sem data prévia para resolução. Total descaso com os usuários!
03-15-2025 07:56 AM
03-15-2025 07:52 AM
Fiz e restauração de fábrica, até pq não sabíamos oq estava acontecendo.
Espero verdadeiramente que vcs solucionem isso, pq não temos nada haver com essa falta de qualidade.
E isso afetou milhões de pessoas e famílias que fazem o uso deste aparelho.
03-15-2025 07:59 AM
03-15-2025 07:54 AM
Good day,
how do I know it when the problem has been solved?
03-15-2025 07:58 AM
Eeeeeeeeh, come si fa? 😉
03-15-2025 07:57 AM
O meu ainda continua sem pegar
03-15-2025 07:59 AM
How do I know it is online if i cant cast to it?
03-15-2025 08:17 AM
Okay, let's take this from the beginning: have you, at any point since last Sunday, done a factory reset on your Chromecast in an effort to get it to work again?
03-15-2025 08:00 AM
Is this still happening as i cannot connect
03-15-2025 08:03 AM
If you've already done a factory reset, then you'll need to do this to allow your Chromecast to receive the firmware update fix that Google started rolling out on Thursday:
03-15-2025 08:06 AM
Have not factory reset, all i get is sillence
03-15-2025 08:02 AM
Mine is on the latest firmare, but casting is still not working
03-15-2025 08:03 AM
Vuelve a funcionar por fin. Si restableciste de fabrica cambia la fecha a anterior 9/3/2025, enparejalo y vuelve a poner la fecha actual
03-15-2025 08:06 AM
Yes. More complete instructions here:
03-15-2025 08:17 AM
Hola, tengo un chromecast segunda generacion con el que viajo frecuentemente. Obviamente cada vez que llego a mi destino vuelvo a configurarlo, qué debo hacer si la ultima red a la que lo conecté ya no está disponible? Entendiendo que necesita ser conectado a internet para recibir la nueva actualizacion con el problema que se está presentando actualmente. Qué debo hacer?
03-15-2025 08:20 AM
Do this to connect your Chromecast to the new Wi-Fi network:
03-15-2025 08:18 AM
I set my phone date 08.03.2025 and add my google chromcast with gppgle home, than chromcast take update and naw work properly.
03-15-2025 08:25 AM
I reseted my Chromecast when troubleshooting and now it still doesn’t work. Fix the problem now, please.
03-15-2025 08:28 AM
03-15-2025 11:13 AM
Joynow, did you have the Google Home app on your phone or tablet downloaded? If not make sure to do download that, then use the "add device" feature and add your chromecast. If you get the authentication error , then change the date in your phone or tablet. (Whichever device you downloaded Google Home on). Change the date to March 7th 2025. Once you do that go back and try to add your chromecast using the "add device" function in Google Home. It should work. When I did all these steps it worked.
03-15-2025 08:25 AM
03-15-2025 08:30 AM
If you performed a factory reset as part of your troubleshooting efforts, then you'll need to do this:
03-15-2025 08:30 AM
To restore device after factory reset, simply use a smartphone on which a date prior to March 9, 2025 has been manually set. After setup via the Google Home app, the device will update automatically, resolving the certificate issue.
