GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,155 REPLIES 16,155
-    If you performed a factory reset during your initial troubleshooting, you'll need to do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Pietra26
Olá boa noite. Estou sem acesso ao Chromecast a uma semana.
--->  If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Bex04nz
If, like me, you did a factory reset before knowing not to... simply change the date on your phone to March 1st before the sh!t hit the fan, chromecast will do the update and then all will be right with the casting world again 😊 you're welcome
Yes, that's part of the trick. But you left out the part about using the Google Home app to reconnect the Chromecast to your Wi-Fi network, which is kind of important. 🙂
Complete instructions here:
ROSA3
Changing the date, but... Does work for iPhone?
Yes, but there's a little more to it than just changing the date on your phone.
Caio2
Já restaurei pq achei q era um problema da minha rede e foi antes d sair o comunicado d vcs oq faço agora
 ----  If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Patriciayumi
Preciso de backup
Pluvera
My iPad won’t connect to my TV
*****  If you performed a factory reset during your initial troubleshooting, you'll need to do this:
blowheadtouch
Ohh my god for **bleep** sake, I seriously thought I had lost my mind. Reset tv and phone, removed and added device.
Only when I check email that I just saw this.
Why couldn't an update come to display on the device or a better alert system as I had no idea.
Is the resolution to upgrade to new devices becuase they'll be discontinued and not supported?
I think I'm gona call the police and tell my mum.
Okthankscyalaterbye
Bassiti
È più di 10 giorni che aspettiamo. Ho due dispositivi non funzionanti. Spiegatemi come fare oppure rimborsatemi la spesa totale per l'acquisto delle chromcast. Grazie
-->>  If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Gueri
Lo tuve que recetear al no saber del problema,  pero esto ya lleva más de una semana, y urge que quede y me den instrucciones para que quede porfavor
---->  If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Vanessa26
Gracias por la información
Vanessa Dos Santos Chagas
Vanessa26
Muito obrigada
Gracias
Slipdani
Estou com problemas no meu tbm!
--->  If you performed a factory reset during your initial troubleshooting, you'll need to do this....
Eu12345
Fiz a restauração de fábrica nele antes de saber que não podia, como faço agora?
Catamarti
Antes de ese mensaje de Google, yo reinicie muchas veces mi Chromecast.  Cuánto tiempo debemos esperar para que se arreglen los dispositivos?
Gracias
Kaotal
That's when the problem is solved?
Lilahnz
Ok I did the change the date on my ph to the 1st march  and it worked it updated but I then had to reset the cast again for it to try to link to wifi with date on phone back to norm however it won't link
What do you mean when you say "it won't link"? Do you mean it won't cast?
Sonja72
is there a more recent update in this issue. It has been over a week that this hasn’t been working!
Google started rolling out a firmware update fix on Thursday.
 However, if you performed a factory reset during your initial troubleshooting, you'll need to do this to allow that update to be installed:
KCHo
I have done a factory reset for my Chromecast.
  *** If you performed a factory reset during your initial troubleshooting, you'll need to do this....
Bearibeiro99
Não consegui nada até agora, inclusive voltei a data porém não adiantou, será que deve demorar muito? Alguém tem outra sugestão?
bigredbrasil
I'm Valter, from Brazil. Translate this message!
Consegui resolver o problema em meu Chromecast de 2° geração, usando a orientação de outro usuário desta comunidade:
-"Nas configurações do seu celular, desligue a data e horário automática e volte para o dia 8 de março; assim você conseguirá
fazer a conexão do
chromecast com a tv, mas ainda não fará transmissão.
P.S. Esse passo é importante pois, só assim, o Google conseguirá atualizar o firmware do seu Chromecast 2° geração. (Verificar
no Google home em
configurações (D versão) 2 se conseguiu fazer o passo acima aguarde até sua firmware atualizar para a versão 1.56.417165.
Estando já com essa
firmware instalada volte a
play story e desinstale (e reinstale) o app Google Home.
Após isso, a magia acontece, para quem
ainda está com a versão de firmware anterior aguarde a atualização do dispositivo, mantendo ele conectado à internet e ligado. Mas nada
disso acontecerá se não
fazer corretamente o passo 1.
Forte abraço e boa sorte!
grb3842
Any advice for brand new CC Audio? In device utility I am getting "We couldn't authenticate your Chromecast Audio".
The solution is the same as for those who have done a factory reset on their "old" Chromecast device. Do this:
