GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,160 REPLIES 16,160
By changing the date on your phone and then you do a new setup to your chromecast from there
Go to your phone or iphone and then go to clock setting and set off update time from gps and set it to 1st march.then connect chromecast and update it.
Fahadii024
Anonymous
Not applicable
Se cambia la fecha del teléfono y despues lo configuras
Graziele
Bom dia , estou a duas sem conseguir usar meu aparelho devidamente, não tenho outra forma de usar a tv ,gostaria de uma solução imediata
Anonymous
Not applicable
Kommer jag få ett mail när jag vet att säkerhetskopiering är klar? Råkade fabrikåterställa när de slutade fungera min chromecast. Min mail är #
Anonymous
Not applicable
buenos días, he restablecido mi chromascaste y por lo que he leído hay un problema, me gustaría saber cómo me lo podrían notificar y cuánto se tardará en solucionar dicho problema,
quedo a la espera,
Gracias
Andresmarced
En serio Google??!! Lleva días sin funcionar, qué onda????
navedali
Hi. It's Sunday and our Chromecast is still showing issue with authentication. I had factory reset it. Now waiting for this issue to be fixed. HEY GOOGLE BE QUICK. THANKS
IEC
Read the replies. You can undo the factory reset by changing the date on your phone.
Tarnz
What happens if u already have factory to reset it. Due to not getting the email about the problem days later
*   If you performed a factory reset during your initial troubleshooting, you'll need to do this...
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Sandrzammit
Hi guys it's been over a week without connection to our TVs due to the faulty castor. Is there any update/an anticipated fix time or are providing a replacement castor.
Eagerly anticipating your reply.
*   -- If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Anonymous
Not applicable
Did the update work for anybody yet? All 3 of my Minis and a Chromecast are still bricked 😆 🤣
IEC
Yes, working again!
Anonymous
Not applicable
Did you hafta do anything or did it just start working again on its own?
IEC
I undid the factory reset with the phone hack to get wifi connecties back. Then chromecast could be seen again by my services (but not yet cast). Just left it plugged in, tried a day later. Works!
JML23
I reset my device, so had to do this.
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
otherwise i think you just turn off everything for 30 seconds and turn it back on, and the update will install itself
EdwinHC
Continua el arreglo para poder hacer un setup del equipo?   Hasta cuando seguimos con el problema?
worked on its own.
.had to make sure youtube didnt start the app on tv, hence cast from tv.
netfllix works fne.
*   If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Zasdrakano
precisamos voltar a utilizar o chromecast 2 urgentemente, é caso de vida ou morte! Socorro!
*  ->  If you performed a factory reset during your initial troubleshooting, you'll need to do this:
al007cool
Please fix this asap, and please ensure better quality control and testing for updates that brick an entire product.
Please let us know when the update has been done.
**>>> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
mariammanso
Por favor, qual a previsão de volta da conexão ???
Vcs vão avisar os usuários de que forma ? Estou tentando todos os dias a conexão na esperança de que o reparo tenha sido concluído e nada.
---> If you performed a factory reset during your initial troubleshooting, you'll need to do this:
I worked it out for myself changing the date back to pre crash but basically same method. All back up and running with the latest firmware installed now.
Nat09
Chrome cast back on 6 days of waiting woohoo
Marcelladiego
Thanks, changing the date on mobile has been successful! Now my Chromecast Is working!
Latina
Siamo arrivati a domenica è ancora mi fa errore . Quanto tempo devo aspettare ?
**** If you performed a factory reset during your initial troubleshooting, you'll need to do this:
mb21uk
Many people here are asking about a fix after many people have already tried the fix with success and explained it here.
Please , lazy people, READ BEFORE YOU POST. Thank you.
Anonymous
Not applicable
Resetee mi Chromecast y ya se ha solucionado. Me funcionó poner en mi móvil una fecha anterior al 9 de marzo de 2025, y así pude configurarlo de nuevo. Luego volví a poner la fecha actual en mi móvil. Gracias a quien dio con la solución y lo compartió en este foro
Yaravdb8
Ik heb de fabrieksinstellingen al lang terug gezet en nu?
