GoogleNestTeam
Community Manager (Admin)
Update 3/20/25
Update 3/17/25:
Update 3/14/25:
Update 3/13/25:
Update 3/11/25:
Hi all,
Thank you.
Thank you for your patience.
GoogleNestTeam
16,123 REPLIES 16,123
Maitenaportillo
Lo resetee de fábrica sin saber que no iba a funcionar más, por favor solucionen este problema
** If you performed a factory reset during your initial troubleshooting, you'll need to do this:
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro
Blidia
Infelizmente redefinir as configurações. E até hj aguardo. Hj faz uma semana, e nada de resolver Google 😔
zewdu
I already have factor resets my chromecast what will happened?
mb21uk
Everyone who has reset their bricked Chromecast needs to understand that you cannot just wait for a fix to be downloaded to it over the Internet because resetting it caused its connection with the Internet to break.  You need to help yourselves by following the procedure many people have already explained here in this thread  (which you will need to find and read), and help yourself to getting your Chromecast back online. Then Google will heal it.
Please don't keep asking questions which have already been answered because you are too lazy too actually read what others have written in order to help you.
Exactly. Use your god-given eyes people, and read!!
johnnyzero2
For all the people who performed a factory reset during their initial troubleshooting, this procedure will allow you to reconnect your Chromecast to your Wi-Fi network, so that it can receive the firmware update fix that Google started rolling out on 3/13.
1) Temporarily set the date on your smartphone (or tablet) to March 7, 2025 or earlier. If you don't know how to do that, see below.*
2) Use the Google Home app to re-setup your Chromecast by adding it as a new device (+). You still won't be able to cast, and the device will be grayed out in the Home app, but that's ok. Most importantly, it'll now be reconnected to your Wi-Fi network so that it can receive the firmware update fix.
3) Change your phone's date/time setting back to Auto now.
4) Sit back and wait for the firmware update from Google to be installed. This should restore your Chromecast to full functionality.
Note: Supposedly it's being done as a "phased rollout", so it could take a while for the firmware update to hit your Chromecast. Also, some have reported that power-cycling your Chromecast (unplug/re-plug the power cable) will sort of "provoke" the firmware update to be installed. Patience.
*How to change your phone's date/time settings:
For iPhone/iPad: go to Settings, General, Date & Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
For most Android phones/tablets: Settings, General Management, Date and Time. Disable "Auto" and manually set the date to March 7, 2025 or earlier.
**Google REALLY should pin this information to the top of this page.**
Nogmaals bedankt
Johan België
Anonymous
Not applicable
Buon giorno, ci sono novità per chi aveva ripristinato i dati di fabbrica nel tentativo di riavviare il dispositivo?
->If you performed a factory reset during your initial troubleshooting, you'll need to do this:
Bikerbabe3939
This is very inconvenient for households sadly. I have 3 Chromecasts that stopped working over a week ago. So my children and I are without tv. Bad week for them to be going out with spring break around the corner.  By the time I found this group which is giving answers, I had already tried everything I could to get them working, including resetting them without any luck. Google should be doing something for us for the inconvenience
https://www.googlenestcommunity.com/t5/Streaming/Regarding-an-issue-with-Chromecast-2nd-gen-and-Chro...
Deze link gebruiken. Je datum smartphone terug zetten naar 8/3 en je kan alles terug opnieuw installeren. Wachten tot hij volledig is geupdated daarna. Datum kan je terug zette na installeren, tijdens update. Bij mij een 2 tal dagen. Nu ben ik terug aan het streamen dankzij een zekere johnnyzero2.
Belgium Johan
SD11
Unable to open devices as the same authentication message comes up and prevents any further access to the device
Fiarel
Change date in the phone to anything before 8th of march
      If you performed a factory reset during your initial troubleshooting, you'll need to do this...
1396
不具合が起き,すぐにリセットをしてしまいました
いまだにつながりません。
早く対処してください
*  If you performed a factory reset during your initial troubleshooting, you'll need to do this....
Hallo,
Sinds vandaag werkt mijn chrome terug. Nogmaals bedankt.
Google een standbeeld voor deze persoon. Kijk maar hoeveel personen geholpen zijn ondertussen. En eigenlijk een simpel trucje noem ik dat. Terug gaan in de tijd. Technologie houd alles in geheugen. Begrijp je 👉😂
Thanks friend
Belgium Johan
Israa
I already performed a factory reset before i know the issue what should i do now
Fiarel
If you’re one of those people who accidentally reset their cast device to factory settings, here’s what you need to do:
1. Change the date on your phone to any day before March 8th.
2. Add the cast device to your home.
3. Most importantly, configure it to work with your Wi-Fi network.
Once that's done, you can set the correct date on your phone. The audio cast still won’t work immediately, but it will start checking for a Google update. Once the update is installed, it should work as usual.
Marta29lima
Nem acredito que depois de dias, finalmente tive meu problema resolvido. Para quem reiniciou o aparelho assim como eu, basta alterar a data do seu smartphone para o dia 7 de março, só assim você conseguirá reconfigurar o chrome cast e receber as atualizações.
07 Março 2025, só isso
Samira1
No.conecta mi chromecast dice que no se puede autenticar
Wolf1301
Não consigo configurar o Chromecast já reiniciei e ele não reconhece
Gbond2
Mude a data do seu dispositivo para 8 de março ou anterior, tente conectar o Chromecast novamente e faça a instalação normalmente. Depois disso, ele vai receber a atualização automaticamente. Quando terminar, basta colocar o seu telefone de volta na data atual.
Espero que ajude.
Sallybest
I did factory reset. But did fix the problem by setting my phone back in time to 7 mars.
Now the chromecast works again 🙂
Samira1
Ya tenéis solución? Mi chromecast sigue sin funcionar
johnnyzero2
***Google REALLY should pin this information to the top of this page.***
Annoying101
This is bull**bleep**! It’s been days without a fix. Do better.
Smirhs
Por favor enviar actualización urgente estamos sin poder nada puesto que no se vincula al ser restablecido de fábrica Arreglen lo por favor Muchas gracias #
Rubi_Gonzalez
Sigue sin funcionar, hasta cuando??
vinibalan
So what’s the latest update? It’s been awhile and I still can’t connect to my chromecast.
Pompispo
Cómo se cambia la fecha?
